Password screen lock cannot be activated phone contacts made are being deleted after demo program have been installed after phone reset. save pictures in camera roll are being deleted after demo program have been installed after phone reset.
SOURCE: want to remove battery in sprint htc touch phone
This unit rquires special kind of screw driver for mobiles or gadgets. Normally, its a star shape screw driver. You must take apart the unit's casing by removing all the screws for you to dry the unit. There's a cover at the back panel that you must remove first
SOURCE: Copying pictures with HTC Hero
If your son has his own facebook page then you can go to the apps store and download an app called syncmypix which will download all of your contacts who are on facebook's profile pic (there may be other apps out there that do the same thing, I'm not sure)
I've only tried this recently so not completely familiar with this but think it will only download the current profile pic.
Haven't got my Hero with me right now so can't play with it to see if there's other better solutions.
SOURCE: want to factory reset an unlocked htc touch cdma (vogue)
All you have to do is...
hold down the (RED) End button and the (GREEN) Send button at the same time, and while still holding them down POKE your stylus in the soft reset hole at the bottom of phone.
Soft Reset button is located to the right of the mini USB charging port, assuming the phone's screen is facing you.
Confirm you want to Format and Done!
P.S.
Sometimes if you don't hold the Green and Red buttons hard enough they tend to unclick and reclick if you don't apply Firm and even pressure.
Also if you still have trouble make sure the phone is in the BOOTING cycle when you attempt this.
SOURCE: I have a htc hero and I add a contact twice .. But
In the contact list select the one you do not want. Go to Options. Select delete and this particular record will be deleted.
SOURCE: transferring pictures from phone to memory card on htc touch pro
I know this post is old but the easiest way to do that is to go into FILE EXPLORER.. and find your PICTURE folder it will show you all the pics on the device tap one of the pics once and drag down until all pics on device r yellow then tap and hold until menu pops u tap COPY once u have them copied as one file go back into MY DEVICE and find STORAGE CARD scroll all the way to the bottom then without touching another pic already there tap and hold the blank bottom then click PASTE and wait all pics will be transferred
