I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link - http://www.shortcutvirusremover.com
Place it in your pen drive and double click to run. Press Enter to confirm its process. That is all. Shortcuts will remove and your data will be back in a second.
Hey i have experienced the same and infact recovered all my folders. search for stellar data recovery.
Use a file recover untility and that should help. I would put a good anti-virus program on the hard disk next time.
SOURCE: my iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
SOURCE: folder structure showing 0 files on external HD -after powersurge
You may use data recovery software to see if you can rescue the files on your external HD.
It may unable to recover all the files, but at least most of them.
SOURCE: my file became a shortcut icon in external hard
Hey Yus_Hafizi,
Often times on windows when you drag a file it will create a shortcut instead of making a copy. One way to copy a file for sure is to highlight the file and then go to Edit -> Copy in windows explorer/my computer window. Then browse to your external HD and go to Edit -> Paste. This will for sure copy the file as opposed to making a shortcut.
Thanks,
SOURCE: MY TRANSCEND HARD DRIVE HAS
Is this the Problem???
Only Shortcuts,,,,,,
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
100% free
Setup file to download 1.1 Mb
Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
download link in home page - http://shortcutvirusremover.blogspot.com
SOURCE: Avira antivirus disappeared folders and files
I too have the same problem it happened through avast antivirus
