Canon PIXMA MP495 InkJet Printer Logo
L
Lori Posted on Mar 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Step by step instructions on how to scan documents to my pc
LP
Level 3:
  • Master 514 Answers
  • Posted on Mar 05, 2014
LP
Master
Level 3:
Answers
514
Questions
Helped
120633
Points
1285
In case you don't have the manual, check this online :
http://files.canon-europe.com/files/soft39530/Manual/Canon%20MP495_499%20EN.pdf
Assuming you have installed the software (from the CD-ROM) successfully, the scanning tools/program (MP Navigator EX) will guide you through the scanning process. See pp. 22-23 and pp 330-338 of the above document.
Grognard
Level 2:
Novelist:
  • Expert 126 Answers
  • Posted on Mar 18, 2014
Grognard
Expert
Level 2:
Novelist:
Answers
126
Questions
0
Helped
33147
Points
345
Personally, I found the Pixma manual singularly unhelpful. Through trial and error, I discovered the following process (Caveat: I'm working from memory on some of this so some specific details like the wording on buttons might be a bit off.)
1. Put first page of document on scanner with top of document to the left.
2. Find Programs>Canon Utilities>IJ Scan Utility>IJ Scan Utility (yes that is there twice on purpose) and double click on it to launch it. A little IJ Scan Utility control panel will pop up in the middle of your screen.
3. The first time you are using this utility, click on the "Settings" button on the lower right, then select "Document Scan" from the menu on the left. Most of these settings are self-explanatory (or don't need to be changed, or both) EXCEPT the "Data Format". If you *ever* want to scan multipage documents, select "PDF (Multiple Pages)" for the format here. This way, after you scan each page it will ask you if you are done or want to continue. If you pick ANY other format, you can only scan one page at a time and each will go into a separate file. Also note: Be sure to make a note of the output directory you set here. You are not given an opportunity to change it at scanning time so you will have to go to whatever directory you specify here to find your files. If you, like me, forget where you told the utility to put them, it can take a while to find them again. When you're finished with your settings, click "Ok" on the bottom right.
4. Click "Document" on the little IJ Scan Utility control panel and the utility will say "Warming Up ... Do Not Open Scanner" (or something to that effect) and then scan the page on the glass. (Note: I frequently get a warning about "low memory" but it has never caused a problem.)
5. After the page is scanned, the utility will provide a couple of buttons: "Scan" or "Quit" I think. If you want to scan another page, put the new page on the glass BEFORE clicking "Scan"; if you're done, click "Quit" and IJ will start putting the output file together. If, in the settings, you clicked "Check Results", you should see a view of your scanned document. (Sorry, I forget what happens if you didn't.)
How to scan a document
Place the document the same way you would for a copy. Then use the step by step guided instructions under the scan button options. You will need a thumb drive computer or some other device to save your document to.
1helpful
I am trying to scan using the 7840W and I do not have the manual- I just need step by step instructions on how to scan a document, name it, store it into my documents, and then email that doccument as an...
you can scan it with adob photoshop, / import from your scanner/, then save as it with format jpeg, where you want, then you can email it with attach file.
How do I scan and save a document using my F4210 HP printer
Follow the link for step by step instructions on how to scan and save a document with your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01567026&cc=ca&lc=en&dlc=en&product=3746674
If you don't have windows vista, at the same website you can choose your operating system and receive instructions.
Scanning
step by step instructions for scanning a document
http://cluetechnologies.com/index.php?topic=687.0
Basic instructions for scaning on a lexmark x1150
Using your MSoffice Word (2003/7) you can simply create a New document and then go to Insert / Picture / From scanner or Camera
select TWAIN scanner and satrt scanning from PC (have your document in Lexmark scanner Tray in).
Accept or modify settings.
Resize or change properties of adquired picture
save the Word Document.
You can also use your Picture processing program (Paint or other)
Open Paint (or Other) Go to file /adquire/ select your scanning device Scan.
Scan documents and e-mail
was there a utility or a cd that came with the printer, and is there a scan button on the printer? That might be easier to do if you have Canon's software, however, if you dont, or dont want to look for it (haha, i wouldnt), you can go to this website and follow its instructions on how to scan a document using windows. The instructions are very clear (they are on the microsoft website) and are made so that anybody can understand them. If you have any problems, feel free to contact me. Or, just post another thing on here.
Scanning a document
The full version All-in-one software need to be installed to scan.
However, you haven't informed anything about the version of operating system that is installed in your computer. However, please follow the below given instructions to scan.
For XP:
Place a document on the scanner glass and check if the USB cable is connected to the computer correctly.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
For Windows 2000/Me/98
2.Click Start then Click Programs then Click Accessories then Click Imaging.
3.From the Imaging application, click File, and then click Select Device.
4.Select the HP all-in-one device from the TWAIN source list.
5.Click File, and then Acquire Image.
For Vista:
Scanning with Paint:
1. Click Windows.
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
You can use all the above given instructions to scan.
If the full version All-in-one software is installed, please follow the instructions from the below article to get the issue resolved.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpu04515
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Hope the above information will be helpfull.
Wish you good luck!
Regards,
Lawrence
Problem with c6180 when used with mac/leopard
Follow below instructions to scan more than one pages to a single document :
1. Open HP solution center.
Click Start - All programs - HP - HP Solution center.
2. Click Scan document - Click Accept.
Computer will ask "Would you like to scan another page?" Say Yes and scan the other side of the document by following onscreen steps.
Thanks
old marine
old marine
ZJ Limited
ZJ Limited
