Health & Beauty Logo
A
Anonymous Posted on Mar 04, 2014
Braun 5615 body braun pocket shaver 370 type 5616 - buy
shaveroutlet.com
Level 3:
  • Braun Master 1,652 Answers
  • Posted on Mar 29, 2019
shaveroutlet.com
Braun Master
Level 3:
Answers
1652
Questions
0
Helped
765212
Points
4209
This model is long discontinued and no longer available.
A similar model can be found at shaveroutlet.com
https://shaveroutlet.com/braun-p-70-pocket-go-aa-batteryoperated-travel-shaver-p-124.html
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 29, 2009
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Cytherian
Gary
  • 126 Answers
  • Posted on Oct 22, 2009
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
VtToolMan
Mark
  • 704 Answers
  • Posted on Oct 23, 2009
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Testimonial: "very helpful"
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Feb 04, 2010
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Jun 29, 2010
SOURCE: Braun 7570 shaver won't switch off!
Most likely, the switch mechanism is broken inside and will need to be replaced. This part comes with the outer housing of the shaver and is available at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Looking for a foil replacement for a 370 Braun Travel shaver
Braun has made two different travel shavers with the model number 370. They do not use the same foils. The foil for the older version has been discontinued by Braun and is no longer available. The foil for the newer version can be found at shaveroutlet.com. See link below.
Read the information there carefully to make sure it i for your version of model 370
http://shaveroutlet.com/shaver-replacement-parts/braun-5609-370-575-pocketgo-foil-and-frame.html
1helpful
1helpful
I have the Braun 360° Complete 8985 Electric Shaver, and ive learned that it is pritty much gonna keep being a money hole. Can any one suggest a self cleaning brand that is more reliable?
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
http://shaveroutlet.com/shavers/foil-shavers/braun-series-3-370-men-s-shaver.html
http://shaveroutlet.com/shavers/foil-shavers/braun-1775-series-1-shaver-p-123.html
1helpful
New foil required for braun 370 travel shaver
Hello MrandMrsInger! You can purchase a new replacement foil for your Braun 370 at the link I've provided below. Basically, you'll be getting a new cutter block and foil for it, as the foils are no longer provided separately.
Braun, now owned by Gillette, discovered that many folks would buy just the new screen (foil) and it would get torn/damaged by a nick in the cutter block blades, so they packaged these wear items as a set to eliminate those very common problems. I had it happen to mine several years ago, so I know why they made the change.
Anyway, here's the website with your replacement parts:
http://www.electricshaverstore.com/get_list_125.htm
Just scroll down to the 2nd item shown, I believe, and you'll see your replacement set.
You can also use the part numbers to try to locate another supplier, if you wish, as these are the actual Braun part numbers provided.
2helpful
Suddenly,the trimmer blade of my braun 8985 shaver has started literally plucking my hair..i don't know wht the problem is
If you've used the shaver for a very long time, it could be that the trimmer part has worn out. You can buy a replacement body for your 8985 that includes the trimmer, from shaveroutlet.com. Replacement is not very difficult (not soldering involved). You pull off the bottom plug socket, take off the sides, unscrew 4 torx screws on the body, and the shaver comes apart. Good luck!
2helpful
2answers
Need replacement battery for braun Model number 5000-type 5724
Shaver Replacement Battery AA NiMh type
NiMh shaver battery pack with easy solder tabs, dimensions of battery are 1 11/16 length x 9/16 diameter. Battery is 1650 mAhWill fits several older model Braun shavers, $9.99. Contact http://shaveroutlet.com/ for detailed info. Older model Braun shaver batteries don't come on a circuit board and involve soldering.
Since I have never dissembled this model ask Shaver Outlet via e-mail if you buy the parts from them. They have been most helpful to me.
2answers
Where do I buy a replacement side-burn trimmer for the shaver?
The trimmer is sold as the back housing assy. I have them in stock. Please call me aty 1-888-643-9806 to order 1. I will tell you how to get the shaver apart to replace. Ask for Action Mike.
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
