Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
A
Anonymous Posted on Mar 04, 2014
Manual for kenmore model 253.23024101
How to replace battery
Replace 9 volt battery in upright freezer of a Kenmore Freezer
What is model # and why would it have a 9v battery?
Where is the 9V battery located on a Kenmore upright freezer model 970
The location of the 9V battery on a Kenmore upright freezer model 970 can vary depending on the specific model and design. However, in general, the 9V battery is typically located in the control panel or on the back of the freezer near the compressor. You may need to consult the freezer's manual or contact Kenmore customer support for more specific information regarding your model.
1helpful
Need manual for kenmore model 28462---water on floor
Contact Whirlpool to see if a manual is available. Whirlpool makes Sears Kenmore.
Kenmore freezer Model # 255.19502010 - Kenmore Refrigerator
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
I need to replace the thermostat on my very old Kenmore Coldspot Upright Freezer, model 106628420. I have no owners manual and there is not one to be found. I would like any help possible. Thank you so...
Not that this diagram is a lot of help, but I did find this on a Sears website:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Freezer-Parts/Model-106628420/0582/0142000?sid=PDVertical
Replace battery
what is model number. Always give model number so you can receive correct help.
2helpful
Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
6helpful
2answers
Kenmore Freezer Alarm
You can take the batteries out that power the alarm system. They are located through a small access panel/door front bottom right of the unit. If you bought the unit at Sears, you should call 1-800-4MYHOME and ask a technician if a replacement manual is available, or if they can direct you to a website for it.
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
