Kenwood KDC-MP235 CD Player Logo
A
Anonymous Posted on Mar 04, 2014
Protect Mode i need to how i fix this problem
How can I get Dynex TV out of "protection mode"?
the protected mode kicks in when there is a safety issue with the receiver. This usually comes from an overload to the system via a short in the system or perhaps a surge in power. Your receiver shuts down, and you'll need to shut the entire system down to fix it.
In some older homes, some of the wiring doesn't deliver the "cleanest" power, delivering minor power surges to the items you plug directly into the wall. If your receiver is plugged directly into the wall, purchase a surge protector to stop this
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYa9W0Mi
God bless you
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYZm8THG
2answers
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
12helpful
2answers
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
It overheated, due to lack of ventilation. Now in protective mode
Disconnect all speakers at the receiver, if it stays on, post a comment and I can help you troubleshoot further. If it stays in "protect" it needs serviced. Hope this helps.
51helpful
3answers
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
3helpful
Amp in protect mode how to fix
good in mode 2 protects from damaging unit u probaly have output wires touchin or inpt wires touching or shorted speaker if does not fix problem diconnect car batt 4 2min this resets pwm circut if no fix u probbaly have shorted opt transitors not expense 2 repair 4parts go2 nte semiconductor.com tran 2/3$ apice probally need 2 4 good luck
1helpful
2answers
Sony str-da90es in protect mode
When these units go into protect mode, they normally have a blown channel. It is not an easy fix, it will require the replacement of a few parts. You would need a multimeter and soldering equipment to determain which parts need to be replaced.
If you would like to fix it yourself let me know and I can help you with it, but it would not be an easy job for you unless you have some experience at troubleshooting electronics.
Display read protected and wont do anything
Usually, protect mode is enabled when the speaker output wiring has shorted together or is touching ground/+12V. I would verify that none of the speaker wiring has come loose.
2helpful
Getting my amplifier out of protect mode
There is a problem with one or both of the audio amplification circuits. The amp is going into "protect mode" to protect your speakers. I'm afraid there is no simple fix. this will need to go to the shop to be repaired...
...unless you have been tinkering with the speaker connections recently. In which case, make sure all connections are sound & there are no wires touching other wires. This causes a short circuit. Leave it disconnected from the mains overnight. There's a slim chance it might spring back to life tomorrow.
Good luck & let me know how you get on.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
