My fridge is leaking from the bottom or the back i dont know which yet. but i see water on the right back corner on the floor. any idea what this could be
Greetings,
I guess, I need to know if its the floor of the refrigerator, or kitchen floor? if floor of refrigerator. Its most likely a drain issue..The defrost system melts the ice and that water flows into a drain. these become clogged from food particles and stop up. The water then travels the path of least resistence and ends up down inside refrigerator. The solution is to open up drain and usually all is well..
Now, if its just on the floor. we have to check all the obvious. it still could be the drain and water could be running out from under crispers onto the floor. So, check that first...if not, check the connections at icemaker valve (if you have one) again, check water line if you have one....make sure the drain hose is in the drain pan...sometimes the drain pan sits above the compressor and heat evaporates the water...these pans get a hole in them I hope this helps..let me know if you need any clarifications....Bruce
