IBM NetVista PC Desktop Logo
A
Anonymous Posted on Mar 04, 2014
Fun cpu stop - IBM NetVista PC Desktop
The laptop swithes it self off after some time
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
My hp dx2000 starts but stops but the chassis fun stop running just after 5 minutes. I tried to change RAMS, HHD, Power supply, fun but no avail. Sometimes it stops immediately it tries to load Windows...
The heat sink may be clogged with dust and ifthe BIOS temperature sensor controls the fan speed then it may be compensatingfor the reduced cooling by the dust build-up.
Your CPU fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
3answers
Machine stopped in mid operation, screen went black. attempts to restart results in a beep code lasting approx 5 sec and repeats every 5 sec. No video.
Sounds like a cpu fail what i call a epic fail n tech terms epic fail means in mid operation when the cpu get at its max ACU until it starts to dump errors into the memory to instrcut the bios of shutdown and beep. Epic fail also means in most games a hard ware failure there are other terms of epic fail do not confuse this of me making fun of you but its a term that is used in the IT industry where a cpu just quits in mid operation. There could be other damage done during a epic fail as in the cpu clock that is automatic go out.
Thanks I do hope this helps receive your Very Helpful rating.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Cpu problem
check your power source.
My tablet pen occasionally stops responding.
what you need to do is go into cmd prompt and type this: /configtab (you need to type it correctly, sometimes you may need all caps or no caps, it depends your software). get the 7 digit code that appears next to "confm" and go to your tablet settings and enter it into the confirmation input. and you are set to go!
2answers
Motherboard
the fun? check your cpu matey and your ram could also be bad if not try resetting your nios by using the sest switch on the motherbaord
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
