The above petrol strimmer is very difficult to start and when started becomes almost impossible to restart again should it have to be turned off during the performance of task
SOURCE: Homelite chain saw difficult to restart after refueling.
Are you pumping the primer till it's full first?
SOURCE: New Homelite 16" chain saw is difficult to impossible to start.
Read and follow the start procedure in the manual, most say to open the choke once the saw attempts to start. Most operators miss this or do not hear the cough and flood the saw. Your manual is probably similar, if not successful with the following maybe time to return it. One thing that might impact starting, what is your elevation? Your saw was setup at near sea level, if you 4000' it may need an adjustment. The store where purchased will probably recommend someone if asked.
Start Procedure
Cold:
Warm:
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
