Hobart Handler 140 Mig Welder Logo
r
ron hackbarth Posted on Mar 05, 2014
Miller syncrowave 300 no power light and no weld power however have 480v input fan runs and can hear gas start when foot petal pushed
Scott Hittle
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Apr 10, 2014
Scott Hittle
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
Helped
15978
Points
19
The first thing to check would be to see if you have open circuit voltage at the weld output terminals when you push the pedal. Make sure the high frequency is off if you are going to to check with a multimeter. After that if you do have OCV but no high frequency to start the arc, try it in start and in continuous. When you put it in continuous it bypasses a control relay. Also check the HF points to make sure they are clean and gapped to about ten thousandths.
1 Related Answer
luis_david
David Soto
  • 414 Answers
  • Posted on Jan 09, 2011
SOURCE: Can i power this unit with my old Miller Bobcat
If your Hobart Mig is less than 250 amps then yes you can, bobcat 225 will give you10000 watts and you require at least 8000 watts for the hobart.
bad computer-its an authorized dealer thing-you can pay 1-200 to get it figured out or buy a HF flux core welder for same price.
yeah-Im all blue in my shop and I said HF...
i would pay the miller dealer to get it fixed.
I have a Miller Syncrowave 250 DX and it has 3 fans, 1 come on as soon as machine comes on and after welding for about 10min the other 2 come on but they are not
Do you mean to say that the other 2 should come on, but are not? Perhaps you are welding using lower settings than before, and the machine just isn't heating up as quickly. Is there a point at which the fans do come on? Say thirty minutes into the job instead of ten? Maybe you were afraid to run it too long without the cooling fans on and so stopped prematurely, before the thermostat turned them on? Check fuses and breakers.
1helpful
2answers
Syncrowave 250 dx fan not comming on
I have a Miller XMT304 in for repair at the moment and it will run full load (250A) on a load bank for 5 minutes before the fan comes on. By the way the fan is 24v DC. I couldn't be sure but your fan may be similar
Hope this helps.
Miller syncrowave 250 tigrunner with gas flow
Your problem is in one of two areas. The controller board inside the unit or a bad trigger on your gun.
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
I could not welding aluminium with Syncrowave 250DX. could you advise me on what's been missed ?
Gas, tungsten shaping,tungsten protrusion, Typeof gas grounding, gas pressure. setting on AC .
2answers
2answers
Dirty weld
clean your metal with a good peace of the green scotch guard scrub pad prior to the weld.Also try turning up your gas and move a little faster when using filler wire,rember to much heat causes a darker dirter weld.hope this helps
Top Hobart Welding Tools Experts
Sean Wright
Sean Wright
oneStan
oneStan
Kardoc
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
