Hi I have noise on all souds and all the time only when I put effects fx1 and fx2 on "no effect setting" noise stops? I have tried everything to reset the keyboard to erase everything but there is no improvement! Could you please tell me what are my options! The keyboard is six years old and I bought it new in 2008!
I'm not sure, but I believe this has a small sound card inside like in a pc and later model guitar amps. This card runs reverb and things like that and it also may have a small power plug going to it. I have found on many guitar amps that when this plug gets dirty, or possibly just a weak connection, they usually create static noises and then it echoes that noise. I hope this helps you.
SOURCE: Hello, Im singing in a piano
One of the 'plate' type reverbs is usually best on vocals. Preset 16, 19 or 26 should be suitable.
Testimonial: "Thank You! I'll try this."
SOURCE: Korg pa800 mic input makes funny noise
First turn the unit off then rotate the input level volume control. If it feels loose pull up lightly on it as you do this. Also rotate all your controls that you don't normally use a lot. Chances are the pots are dirty. If that doesn't help you might want to check all the connectors inside the unit if you feel confident enough to go poking around. Other wise I suggest that you find a shop that will fix the problem. If you do go poking around make sure the units unplugged and that you have grounded yourself against static discharges.
SOURCE: Korg mini kp only some effects working. Low sound output
I have the same Kaoss Pad mini and have exactly the same problem. I have asked for a solution as well!
The only way I have been able to use live is to turn up master on mixer to compensate, but this is incredibly hard to do if you're not always going through the KP as you have to adjust master volume each time up or down.
I haven't heard any volume problems with the full size Kaoss Pads, think it might just be a KP mini problem.
johnclark
Hi J Wade. I'm Dave P. I'm not a guitar amp expert or technician but I've been using amps and effects for 35 years and there are a couple things I can suggest.
That kind of periodic noise/switch noise can be a symptom of having the polarity of the amp reversed. If your amp has a 3-position OFF/ground switch, try reversing the ground. If it doesn't, take the plug and turn it around. Just don't get near a microphone unless you're sure your amp is grounded the same as the P.A. It could fry your lips off.
Dirty switches to that too. You said the noise is in time with the delay's tap time which is set by a foot switch. If tapping that switch the first time generates a pop, the delay may have catch it and is repeating it. Turn off the amp, remove the delay foot switch and turn it back on. Still noisy? If not, give the foot switch a good cleaning.
When you turn the EFFECTS knob up, is it scratchy? Might need the potentiometer cleaned. What happens when you specifically turn the DELAY level down all the way while using the other effects? Noise still there?
That's all I've got. Hopefully, it was helpful. Don't wrack your brain over this too much. There could very well be an internal problem with your amp that will require a trip to the shop. You don't want to open it up yourself. Rock on but be safe.
Dave P.
Testimonial: "Very fast and useful response. Thanks for the help."
