Inspire EWF14589W
Check your washer inlet valve. If it is sticking shut, (I just had one that stuck open and flooded the laundry room), it will not let any hot water into the tub. To test: set the washer to fill with hot water if all you still get is very little cold water or no water at all the inlet valve or the circuit board itself may be to blame. I have added a pic of a GE inlet valve for an example. They are generally not hard to replace with a few simple hand tools (screwdriver, pliers, nut drivers or sockets). Last one I bought and replaced (in about 20 mins) cost around $20. Where you hook up your hoses is one end of the inlet valve.
