WHEN I TRY A FRESH install of windows 7 my dell inspiron 5150 gives me this message No_more_irp_stack_locations
SOURCE: Crash and Burn dell inspiron 8600 Help
my computer when start I saw the logo of windows, but faster the screen its turned black and dont nothing. I reboot all componet and give me a msg fan are RMP=0, and the hard disk do nothing too.
SOURCE: Windows Error Recovery
Try booting with the disk that came with the computer and start over with a fresh install of windows
SOURCE: dell inspiron 1520 error code 2000-0146
I had the same problem and came across this solution that worked for me as well:
Re: windows Vista will not start
18 Aug 2009 07:28PM
I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
SOURCE: 7 beep error message for
For the Dell Inspiron Mini 1012 Netbook, 7 beeps indicates bad memory (system RAM). The memory will need to be replaced.
The RAM can be replaced using a small Phillips screwdriver and removing the back-plate on the bottom of the laptop. When you see the memory (sticks around 3 inches long), pull those out and put new ones in. Make sure it's the correct DDR2 memory.
I HAVE DELETED THE PREVIOUS OPERATING SYSTEM THEN FORMATTED IT, THIS WAS DONE TWICE STILL THE SAME PROBLEM, I HAVE INSTALLED ANOTHER HARDRIVE AND STILL RECEIVE THE SAME MESSAGE NO_MORE_IRP_STACK_LOCATIONS THIS IS A THREE GIG MEGAHERTZ LAPTOP WINDOWS 7 SHOULD BE A SNAP!!! IS THIS A DELL ISSUE??? WILL SOMEONE PLEASE PROVIDE A SOLUTION TO THIS PROBLEM
Is it a 32bit Windows 7? Is the installed memory 1GB or more?
yes itr is 32bit and yes it is exactly one gig of memory. windowsxp pro worked perfectly in it
How many GB is the installed hard drive?
