Xerox Phaser 8860MFP Printer Logo
Skate Nate Posted on Mar 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display panel will not light up
Machine turns on but display panel does not operate
Gary
Level 2:
Novelist:
  • Xerox Expert 301 Answers
  • Posted on Mar 16, 2014
Gary
Xerox Expert
Level 2:
Novelist:
Answers
301
Questions
Helped
141798
Points
480
If the machine is able to make copies, print or receive faxes, then the display is most likely defective and needs replaced.
How do i change cm to inches on my Brother SE400 embroidery machine
Follow the instructions below to change the measurement to either inches or millimeters
1. Turn on the machine.
2. Press on the operation panel.
- The setting screen appears.
3. Press .
4. Press to display inches or millimeters.
5. When setting is complete, press .
Click here to display all models covered by this answer.
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
1helpful
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
2answers
Washer is turning on and off water starting and stopping
Hi just read your posting.When you say 'It stops completely" does that mean the machine turns off with no lights or display on the top panel?Or when it stops completely the machine beeps and a series of lights light up or an error code appears in your display if you have the display model?Please reply with additional information on the questions and I am sure I can help you rectify this problem
I have a afico 1027 which the language available in the user tool are only german and spain. but i need english..how do i settle this problem..please mail me [email protected]
looks like u need english language uii need to upgrade firmware but its not something ricoh will give away. the cover is on LHS 1 or 2 screws cant remember.
1. Turn off the main power switch.
2. Remove the application cover [A].
3. Insert the IC card [B] containing the software you wish to download into the
card slot of the controller.
4. Turn on the main power.
5. Follow the instructions displayed on the LCD panel
6. Monitor the downloading status on the operation panel.
• While downloading is in progress, the LCD will display “Writing”. When
downloading has been completed, the panel will display “OK”.
• For operation panel software, the Start key lights red while downloading is in
progress, and then lights green again after downloading is completed.
$CAUTION
Never switch off the power while downloading. Switching off the power while the
new software is being downloading will damage the boot files in the controller.
7. After confirming that downloading is completed, turn off the main power and
remove the IC card.
8. If more software needs to be downloaded, repeat steps 1 to 7.
9. Turn the main power on and confirm that the new software loads and that the
machine starts normally.
NOTE: If the download failed, an error message will appear on the panel. Then,
download the firmware again using the IC card as usual.
B022S999.WMF
[A]
[B]
I have a Canon MP830 & I can't print or send a fax Error message 300 - I can't turn off the printer - & it says I have 10% in memory. it is also making a clicking noise
Error No. 300 :
Cause 1: The machine is not ready.
Action : Ensure that the lamp on the Operation Panel lights.
If the lamp on the Operation Panel is off, turn the machine on.
While [COPY] is flashing, the machine is initializing. Wait until [COPY] stops flashing and stays lit.
When the Alarm Lamp lights orange, an error may occur in the machine.
Cause 2 : Machine is not proper connected.
Action : Ensure that the printer cable is securely connected to the computer/
* If using a switching hub or other devices, disconnect the machine and reconnect it directly to the computer and try printing again. If successful, the problem may have been with the device.
* There could also be a problem with the cable(s). Replace the cable and try printing again.
Cause 3 : The name of the machine being used is not selected in the [Printer] pull down menu of the [Print]dialog box.
Action : Select [MP830] from the [Printer] pop-up menu in the [Print] dialog box of the printer driver.
If the [MP830] is not displayed in the printer list, follow the procedure below to confirm the settings.
1) Select [ Print abd Fax Preferences] from the [Printer] pop-up menu.
2) Check that [MP830] is displayed in the screen that is displayed and select the [InMenu] checkbox.
3) If [MP830] is not displyed, click [+] to add a printer.
If [MP830] is not displayed, install the MP Drivers again referring to the Easy Setup Instructions for the operations.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
3helpful
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
BLACK OUT LCD DISPLAY AND PANEL NT FUNCTIONING
hi,
seems like a silly question, and i dont know about canon copiers, but on my toshiba, underneath the key panel there is a scroll button that turns the brightness of the lcd up and down, if hit by accident, as often happens the lcd appears black. It has tricked me before!! haha
Take care
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
