Horizon T901 Treadmill Walking Belt Logo
Chuck Reed Posted on Mar 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Runs without load
I have the t901 that was sitting for a while.. It will start and run but It will throw the breaker if you start with a person on board. I have lubed everything and it does not seem to be under undue tension . It will run forever without anyone on but when you start it with someone on it the breaker I'll trip, breaker is good
Ross Metcalfe
Level 2:
Novelist:
  • Expert 135 Answers
  • Posted on Mar 05, 2014
Ross Metcalfe
Expert
Level 2:
Novelist:
Answers
135
Questions
Helped
79733
Points
314
It either needs a walking belt/deck or a motor.
Tahoe lxr 7000w generator
Power leaks can be caused by a combination of moisture, dust, or worn-out wires. When the GCFI detects a difference in the electrical input and output, the breaker will trip, preventing potential fires or electrocution.
Runs good throws breaker
I know this sounds simple but have you cleaned the filter. Billy
Sep 17, 2014 • Dryers
1helpful
Why does my motor stop.
The motor has an internal thermal ckt breaker. The load is too heavy. Suggest changing the belt pulley ratio to lighten load on motor.
A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
Trailmanor water heater throws breaker when running on electric.
Contact atwood. there should be a number in your lterature. They can tell by the serial no. hold ols it is and may direct you to a facility for repair. Good luck
Whirlpool Dryer won't start
You probably had been using the dryer alot today. As long as the motor was running there was enough air flow over the motor to keep it just cool enough to allow it to continue to run. When you stopped the dryer the heat tripped the thermal protector in the motor. Let it sit an hour or so and it should restart. The motor is probably coated in dryer lint, and / or the motor bearings are getting bad. If you space your drying loads out a bit you can get by for a long time without having to do anything.
Sep 16, 2008 • Dryers
1helpful
Dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
Top Horizon Exercise & Fitness Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
