SOURCE: Oil leak
Hello Pierre,
A little more detail may help me on this one, however this sounds like possibly your power steering pipe? both these use auto trans fluid it is reddy brown in colour and viscosity (Thickness) watery.
If this is the pipe, check the fluid reservoir it should have either a Yellow top with power steering or a steering wheel diagram on it.
If full then please give me more information as to location on engine where pipe comes from and goes too as nowadays engine oil is usually internally dispersed. Only oil cooler pipes possibly? will go to a finned type radiator usually near the front grille of the vehicle.
I hope this points you in the right direction as I'm thinking of giving this help up as very hard to remain on top slot when loads of questions responded to and no replies.
Good Luck,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
SOURCE: renault megane engine light flashing and car is juddering.
I have 2 meganes im working on at the moment both have the same problem. the electrical falt light is on coz the pipe has snapped (or come off) under the bonnet on the passangers side close to the window (theres a black box about 2 inch wide the pipe connects underneath). if I reconect the pipe and grab the engien with both hands it wobbles and the pipe pulls off. I suspect this is coz one (or all) the engien mountings are shagged. and this will be the cause of the juddering when driveing in first and second gears. solutions iv have come across for juddering involve changeing the coil pack but thats nothing to do with the problem my 2 cars have as one of them has new coils. they are 1.6 petrol, p reg and s reg
SOURCE: Renault 2.2 Safrane executive M reg auto gearbox
for topping up the transmission at the front of the gearbox there will be a rubber bung pull that out and top up with atf fluid, if topping up don't work then there could be a electrical fault check all wiring to gearbox for corosion
