There are many ways to attempt a fix with this error you could try firsta boot into safe mode then running msconfig
select the diagnostic startup then reboot in the normal way this might enable you to find your error.
If this fails click the LAUNCH SYSTEM RESTORE which maybe able to use one of your restore points created at an earlier time (usually before an app install) this may give you the fix you require.
