Question about Microsoft Windows XP Professional Edition With Service Pack 2 for PC
I CAN'T RUN / START TRIAPC.EXE - Microsoft Windows XP Professional Edition With Service Pack 2 for PC
    Master:
  • Microsoft Master
  • 788 Answers
Test your software and fix it using Norton Utilities (download and run it):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Posted on Mar 04, 2014
SOURCE:
How to Remove Csrss.exe?
Deleting Csrss.exe With Regedit.
Click "Start," select "Run" from the Windows Start menu and type "regedit.exe" in the Run box.
Back up your registry before making any changes. Click "File" on the Regedit menu, then click "Export." Save the exported registry file to a safe location on your hard drive or external storage media.
Click "Edit" in the Regedit menu and select "Find."
Type the following path into the search box: HKEY_LOCAL_MACHINE\Software\Csrss.exe Click "Find next" to search for the file.
Right-click on the "csrss.exe" file in the search results and select "Delete" from the context menu.
Click "File" and "Exit" to close Regedit.
Oct 20, 2016 | Microsoft Computers & Internet
Tip
HP printer UNINSTALL using CD
<p><span><b>Resolution:</b></span><br /> <ol> <li> <span>Run the uninstaller from the SETUP.EXE driver</span> <li> <span>Delete printer from Printers folder</span></li></ol> <p><span><b>Removing printer using the SETUP.EXE driver:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <p><span><b>Deleteing Printer:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <br />
on Mar 10, 2011 | Office Equipment & Supplies
Tip
How to customize your start button
First you need a tool called "Resource Hacker". This free program allows you to change resources in any .exe file such as "Explorer.exe", which includes the [Start] button's Label. You can visit Download.com and search there for "Resource Hacker".
After you download it, follow the guide here:
Step 1:
A - Run "Resource Hacker" and open the file "%windir%\Explorer.exe".
B - You see a Tree of all Resources in this file, expand the "String Table"
C - Find the "start" and replace it with your own text. then press the [Compile Script] button.
D - Save "Explorer.exe" as "MyStart.exe" DONT save it as Explorer.exe, do "save as.." and give it a new name.
E - Quit "Resource Hacker".
Step 2:
A - Click on the [Start] button and choose the "Run..." item from the start menu. (Or use the shortcut key WinKey+R)
B - Type "RegEdit" in the Run "Dialog Box". And then press the [Ok] buton to run the "Registry Editor" program.
C - Go to: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon" and find the "Shell" property.
D - Replace value of the "Shell" property to "MyStart.exe".
E - Quit "Registry Editor".
F - Restart your system.
Note about Registry Editor:
if you did not find the key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon", you can search the Registry for the "Explorer.exe", to do this use the Edit Menu | Find Next (Ctrl+F).
AmirBehzad Eslami's site has a handy tool for altering your start button, which makes life much easier, you can find his site here:
h**p://www.startbtn.main-page.com
on Mar 06, 2010 | Computers & Internet
Cant run morbidelli programming software
In order to run the Morbidelli software you MUST have at least Microsoft Windows XP OS and - XILOG PLUS
so you need more than just windows XP. do you have XILOG software.
you must contact the seller:
http://www.exapro.com/question-to-the-seller/morbidelli-universal-2412nb-like-new-wood-cnc-machining-centre-p30911116/
Feb 27, 2014 | Microsoft XP Computers & Internet
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Windows cannot find gphone.exe??
Gphone.exe is a file that an instant-message worm infects. This worm spreads through Google chat and Yahoo! Messenger. This “Gphone.exe” worm disables your antivirus security software, and downloads more crapware onto your PC.
To remove do this:
1. Block Gphone.exe sites: http://rnd009.googlepages.com/
2. Stop Gphone.exe processes: %Windir%\gphone.exe
%System%\gphone.exe
%System%\DEFAULT_NOT_SET.exe
C:\Documents and Settings\All Users\Desktop\gphone.exe
%Temp%\gphone.exe
%System%\gphone.exe
%DriveLetter%\New Folder.exe
%DriveLetter%\gphone.exe
[ROOT FOLDER]\New Folder.exe
[ROOT FOLDER]\gphone.exe Get rid of Gphone.exe files:
%DriveLetter%\autorun.inf
%Windir%\Tasks\At1.job
[ROOT FOLDER]\autorun.inf
C:\disk.txt
%System%\autorun.ini
%System%\setting.ini
%Temp%\log_[TIME AND DATE].txt
3. Delete Gphone.exe registry keys using regedit from start - run:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\WorkgroupCrawler\Shares\”shared” = “[ROOT FOLDER]\New Folder.exe”
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\”Yahoo Messengger” = “%System%\gphone.exe”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\”Shell” = “Explorer.exe gphone.exe”
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Schedule\”AtTaskMaxHours” = “0′
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Schedule\”NextAtJobId” = “2′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\”DisableTaskMgr” = “1′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\”DisableRegistryTools” = “1′
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\”NofolderOptions” = “1′
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Default_Page_URL” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Default_Search_URL” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Search Page” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\”Start Page” = “http://rnd009.googlepages.com/google.html”
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\”Start Page” = “http://rnd009.googlepages.com/google.html”
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer\Control Panel\”HomePage” = “1′
HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Control Panel\”HomePage” = “1′ Note: In any Gphone.exe files I mention above, “%UserProfile%” is a variable referring to your current user’s profile folder. If you’re using Windows NT/2000/XP, by default this is “C:\Documents and Settings\[CURRENT USER]” (e.g., “C:\Documents and Settings\JoeSmith”). If you have any questions about manual Gphone.exe removal, go ahead and leave a comment.
How to delete Gphone.exe files in Windows XP and Vista:
1.Click your Windows Start menu, and then click “Search.”
2.A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
3.Type a Gphone.exe file in the search box, and select “Local Hard Drives.”
4.Click “Search.” Once the file is found, delete it.
How to stop Gphone.exe processes:
1.Click the Start menu, select Run.
2.Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys CTRL + Shift + ESC.
3.Click Processes tab, and find Gphone.exe processes.
4.Once you’ve found the Gphone.exe processes, right-click them and select “End Process” to kill Gphone.exe.
How to remove Gphone.exe registry keys:
Because your registry is such a key piece of your Windows system, you should always backup your registry before you edit it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or value, there’s a chance you may need to reinstall your entire system. Make sure your backup your registry before editing it.
1.Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
2.Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
3.To find a registry key, such as any Gphone.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Gphone.exe’s registry keys.
4.As soon as Gphone.exe registry key appears, you can delete the Gphone.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Gphone.exe DLL files:
1.First locate Gphone.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
2.To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Gphone.exe DLL file is located. If you’re not sure if the Gphone.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
3.When you’ve located the Gphone.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Gphone.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Gphone.exe change your homepage?
1.Click Windows Start menu > Control Panel > Internet Options.
2.Under Home Page, select the General > Use Default.
3.Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
4.Select Apply > OK.
5.You’ll want to open a fresh web page and make sure that your new default home page pops up.
Gphone.exe Removal Tip
Is your computer acting funny after deleting any Gphone.exe files? I recommend using a program like File Recover from PC Tools. File Recover saves deleted files that otherwise can’t be recovered by Windows operating sytem.
Want to save time finding Gphone.exe files? Download Spyware Doctor, let it find the Gphone.exe files for you, and then manually delete Gphone.exe files.
Aug 04, 2009 | Microsoft Windows XP Professional With...
Windows script host
My Documents Folder - Opens Upon Boot
To Stop Windows Explorer from opening My Documents: Check your settings here: Start/Run/Regedit
In the right pane under Userinit - Change the key that reads:
C:\Windows\System32\Userinit.exe,C:\Windows\System32\Userinit.exe
To:
And also here: Start/Run/Regedit
Start/Run/Regedit
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows. In the right pane, check your settings under Load.
try this rate the solution
Jul 06, 2009 | Computers & Internet
Funny UST scandal!!!
How to remove the virus:
first download taskiller in here or here and install it to your computer because you can’t use task manager to terminate the virus(the virus automatically close task manager).
run taskiller and left click it on the system tray(the one with a skull icon)
click processes
to close the virus, select process and click yes to the question
(process to close)
  1. killer.exe
  2. lsass.exe
  3. smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
  1. now, click “start” then “run”
  2. type “cmd” without quotes
  3. type “cd\” without quotes
  4. type “attrib -h -s smss.exe” without quotes
  5. type “attrib -h -s autorun.inf” without quotes
  6. type “start c:” without quotes (a new window will open)
  7. select smss.exe, autorun.inf, Funny UST Scandal.avi.exe and delete it
If theres any drive or a partition type “d:” in command prompt without quotes “d” is the drive letter then repeat the CMD STEPS number 4-7 above…….
  • now type this on the command prompt “cd windows” without quotes.
  • type “attrib -h -s smss.exe” (without quotes)
  • type “start c:\windows” (without quotes)
  • delete the file smss.exe
  • now, goto c:\documents and settings\all users\startmenu\programs\startup
  • delete lsass.exe
type “regedit” without quotes then delete the registry entries above….
“VIRUS REMOVE”
Or just simply download this UST VIRUS REMOVER (not tested)
Mar 20, 2009 | Microsoft Windows XP Professional With...
Antivirus 2009
I see these every day, note: also fixes AV 2008 and many others.
This Malware is known as "Rogue anti-virus" software.
This program will remove it: http://www.majorgeeks.com/downloadget.php?id=5360&file=10&evp=2e0d43eb67e1e71c0b31e62c003599c0
the website that has it also has a really good antispyware program called malwarebytes
www.malwarebytes.org
once you run a full scan in this program run this program:
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
it's another free antispyware. these are both professional grade removal software for free. I remove this stuff about 3 times a day. It seems this outbreak is the largest I've ever seen.
If you want a good protection suite that will keep it out buy a copy of NOD32 (www.nod32-av.com) another you may not have heard of, it will block this and many others before it even gets on your computer.
Jul 17, 2008 | Balance CN6555 Notebook
Funny UST scandle.avi (Virus)
I done research on this but not tested to my computer ..just try this remover created in philippines . this the link: http://www.geocities.com/six519/Remover.zip may this help.
Dec 11, 2007 | Computers & Internet
Microsoft Windows XP Professional Edition With Service Pack 2 for PC Logo
132 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
