Televison & Video Logo
Posted on Sep 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
42'' Samsung Plasma Tv Screen went black but the sound works.
We have a 42'' Samsung Plasma TV, model #HP-S4253 . One day the screen completly shut off/went black. The sound still works, there's just no image. Is there some kind of fuse that may have blown? The tv is about two and a half years old. We had some problems with the screen and had it replaced about a year ago. (White dots had started to appear). Any ideas?
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Sep 23, 2017
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14985404
Points
237762
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
5 Related Answers
Anonymous
  • 93 Answers
  • Posted on Aug 17, 2008
SOURCE: Samsung S4253- No Image, Only Multicolored Pixels; Sound OK
I had the same problem. Luckilly I had an extended warranty. Repair tech said it blew three main boards inside and to fix it out of pocket would have been more than the screen was worth. Hope this helps.
Anonymous
  • Posted on Aug 21, 2008
SOURCE: plasma TV with vertical lines
Help! My Plasma by Magnavox is putting black verticle lines on the right side of the screen - comes and goes - and I replaced the entire Direct TV-HD unit - wires, everything - and had TV company repair - and it still came back. The TV repair refuses to take TV back because it does not show up when they come. Although I videotaped it and showed them which has the date and time - they still refused to take it - and tried to get me to sign a paper saying it was working while they were there - which of course I refused to sign - so they left and nastily said they will not be back-find someone else. I still have the lines - and do not know what to do! Can anyone help?
Anonymous
  • 84 Answers
  • Posted on Oct 18, 2008
SOURCE: Panasonic Plasma TV 42 inch
need the model # so i can help you further
Anonymous
  • 744 Answers
  • Posted on Feb 12, 2009
SOURCE: Screen Problem
hi....Your tv picture is managed by several boards, the two specific ones are the ysus and the xsus. The Y controlls the horizontal pixelation and the X the verticle, if you are having horizontal problems then its the Ysus thats faulty, on this particular set, the Ysus board has two accompaning buffers that are particularly troublesome. I've had more than one of these sets in the shop recently with the same ailment.Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it?  When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again..
thank u rate me!!
PanamanNE
  • 9 Answers
  • Posted on Aug 14, 2009
SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
Picture goes out in less than a minute but sound keeps going
Typical problem in some video/audio board. However, if this only occurs on a particular video input ie: dvd or vcr, it may just be your wire connection.
My Samsung HD-S4253 42" plasma TV will not turn
did you ever find a solution? Mine is doing the same as of yesterday
Richard [email protected]
I have a samsung r4252 plasma 42". Half the screen has black lines. what should I do?
If you can open your plasma and remove all connector given.Cleaned and refit properly it should work
Plasma tv
bad y buffers , your model may have only one y buffer and you may need a Y main too. voltage checks can confirm VS and VA voltages marked on board plugs and tag inside TV
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Screen has gone blank. Is this common? Fixable?
Contact us to join our group who is taking action for the same issue. [email protected]
2answers
Samsung HP-S4253 black screen, with sound
Its the broadcasting company and there "new technology" Have had an over the air box to get local HD channels and lost my PBS station, turned out to be a new signal incompatibility. The same is with my HP-S4253. Must not have the latest SW to process the new signals
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Samsumg plasma tv 42
it sounds like the panel is bad..if it is less then a year old you should contact samsung
2answers
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
