Starting instructions per manual.
- Make sure bypass rod is pushed in.
- Sit in seat.
- Make sure mower is disengaged. (See Engaging and Disengaging Mower in the OPERATING section.)
- Lock the park brake.
- For automatic models, put transmission shifter into center slot.
- Parking brake - ON
If it still doesn't crank, cycle the safetys.
- Parking brake - OFF/ON
- PTO - ON/OFF
- For automatic models, move shifter out of center slot then back.
- Seat switch - Rise from seat then sit firmly.
If still no crank, check battery charge is at least12.5VDC. If battery ok, then likely a safety switch has failed or misaligned. Try rotate and hold ignition switch at start position and see if moving safeties allows crank. Move out/in seat, pull PTO switch on push off, move brake to off then back on. Other possible causes include fuse, ignition switch, relay, poor circuit continuity (power, control, or ground).
