Computers & Internet Logo
A
Anonymous Posted on Mar 04, 2014
Can not make the picture smaller or larger
Game picture is too large and I cannot make the picture smaller and keep it there.
Nenad Davidovic
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 18, 2016
Nenad Davidovic
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
248
Points
5
Chnage the resolution from game menu to the one that is good for your device. If you dont know to what resolution you need to go, leave here some info.
Picture keeps blocking on led tele
Do you mean you get large blurry blocks (pixellation) where and when there is a sudden change in the picture? This can happen when the video processor is unable to keep up with the material. Perhaps you are trying to watch 720p material with the resolution set to 1080p, or vice versa (the extra conversion step takes more processing time). Try changing the resolution. Also, try an interlaced format (720i or 1080i) if that is available on your set.
Generally, you will get the best results if you set the resolution to be the same as your LCD panel (most of the larger ones have 1080 lines, but the smaller sets usually have 720 lines). Check your owner's manual for more information (if you can't find it, look it up on Samsung's support page for your model.
The Tv screen is much smaller during video games than what it is during Movies. Please Tell me how to adjust my screen size.
Movies are shown at a higher resolution than games. That is why the picture is smaller with games than movies. If you turn the Auto Picture Size off, you can set lower grade video to a larger screen size but you will lose quality.
Hope that helps.
How do I make the screen as large as the TV? I was told but forgot.
Go the view mode button on ur remote push it up down to select the picture larger or smaller.
3helpful
2answers
Replaced primer bulb and fuel lines, now it won't stay running
The smaller line is the supply to the carb. and should have the filter in the tank, with sufficient length to allow fuel pickup from the bottom of the tank.The larger line returns excess fuel and pressure to the top of the tank.By squeezing the bulb and watching the fuel lines you will be able to determine if you have them right on the carb.
2helpful
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
2helpful
How do i change to the smaller black ink tank on the canon pixma MP630 when the large one has run out? Thanks, Lynne
You cannot change to the smaller cartridge when the larger cartridge (PGI15BK). The smaller cartridge is used for photo printing along with the Y,M, and C cartridges. You must replace the larger cartridge to be able to print text.
Math
Correct me if I'm wrong but are you asking what an exponent is? If you are an exponent is the small number to the upper right corner of a number. the larger number is multiplied by itself by the smaller number (ex. large 4 and small 5= 4x4x4x4x4= 1024)
Diesel Fuel leak of of large nut in backside of injector pump
do yourself a favor and take the truck to a fuel diesel injection shop the larger nut is just a cover but the smaller one is an adjustment if you remove either on you could damage the pump
1helpful
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
