Dog chewed thru wiring harness, need a wiring diagram for a troy bilt lawn tractor in order to repair, or am I going to be stuck having to buy a new harness
I would first look under the machine, check the wires leading to the pto clutch. There should be a connector/plug, make sure it is clean and plugged in completely. Also, check the wire harness grounds to the frame. Otherwise, you'll have to check the switch, power going to the switch etc. Usually, they are wired thru the safety switch harness so, could be a bad saftey switch, or bad pto switch. You'll just have to start testing wiring.
If you are going to replace them yourself, you can go to www.jackssmallengines.com and should be able the look up the parts diagram by model # and order then on their web sight.
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!! http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
model number from under seat?
