The little spring inside the electric stapler fell out when I was trying to unjam it. Where does it belong and how do I put it back in?
So I just figured out the whole issue with not being able to figure out where the spring goes in the "BOSTITCH ELECTRIC STAPLER" So pull the slide out and the spring slides to the very back of the inside of the stapler. Once in the back put the slide back in and then the staples close it back up and get back to stapling. YOUR WELCOME.
With the power off, remove the three screws from the bottom. The top cover should come right off. Holding the bottom cover to the internal components board are four gold colored screws; remove them and pull the bottom cover off. The spring can just be slid back over the plastic nub below the staple stage. If it's falling off, try using a small amount of super glue around the base. Replace the covers and screws in the same order you removed them and it should work.
Hello, Go to this website for support phone numbers and too download manuals for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
