KUERIG Keurig Platinum B70 Brewing System Logo
C
Cindy Fender Posted on Mar 03, 2014
The Kuerig won't make a full cup - KUERIG Keurig Platinum B70 Brewing System
Albert H Childs
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Mar 05, 2014
Albert H Childs
Contributor
Level 1:
New Friend:
Answers
14
Questions
9
Helped
4597
Points
22
Your not putting in enough water.
Why kuerig vue will not brew complete cup
Sometimes Air gets trapped in the system.Unplug Maker, Remove Water Reservoir, Tip unit at about 45 degrees over the sink to partially drain. Place back on Counter, refill reservoir and replace on Maker. Plug it in and turn it on. make a couple of large cups of hot water then give it a try with coffee
How to fix my kuerig it has water come through the kcup with out making a cup selection? and if it does once in awhile let me make a choice of cup size it gives me 1/4 cup then when I close it again i
The scope of electronics on that unit would need to be serviced by a authorized personnel . Take it back to the store for a refund, or purchase a new one. AC
Kuerig keeps brewing without pushing button
my kuerig has water come through the k cup when I close the top without pushing brew cup size and if it does let me make a selection it brews 1/4 of cup I have descaled it 4 times locked in the water reservoir cleaned the needles turned it on and off any other suggestions to try would be greatly appreciated thank you
My kuerig onecup won't turn on
Internal breaker has fractured and needs replacement.
Cusinart coffee pot single serve with kuerig cups switch won't turn on
The problem is often that the machine develops a leak in the hose that is right over the transformer...the water drips onto the transformer and kills that... then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig One Cup Coffee Brewer will not turn on
heatman101
1helpful
My light won't go out and I descaled it then one light on the cups only lit up and it only gives a little water it's the kuerig i don't know the model
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
I sent you a message yesterday and as of 3:45 today no one has sent me an answer I have kuerig coffee maker and it does not make a full cup of coffee in the mornings what can you do to help me solve this...
Hi.You may try thiis steps.
took the reservoir off,
siphon water from a hose, blow it off
Maybe that is what has happened in
all of these instances
and getting the air bubble out gives us
a full cup of coffee.Hope this helps.
My kuerig doesnt release water into cup what could be wrong
heatman101
Top KUERIG Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a KUERIG Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
