SOURCE: need help on my TP-LINK TL-WR740N 150Mbps Wireless
Here's a GuessYa. Make sure you have the correct and exact DNS servers. If you screw them up, you'll be able to get cached pages, but new pages or functions will crash. It's a funny thing when you find it for the first time :-)
Carl
SOURCE: how to configure TP-LINK TL-WA730RE
you can get the manuals of how to configure tp-link tl-wa730re..just go to google and type free tp-link tl-wa730re manuals.
SOURCE: i have a TP-LINK TL-WR940N
I have the same problem. Some people says that its because of interference from other neighbors' wireless signals or any other in the surrounding etc.You can go to Router Properties and change the CHANNEL to 6 or 11 and observe any changes.
SOURCE: I am using two WAN
I'm a user 4 the same load balance product, your 2 ADSL lines must have difrent IP with difrent submask than the IP you assigned 4 TP Link-TL R480t+ (10.0.1.1 in Ur case), lets say 1st line connected to the Line through a Dlink router has an IP 192.168.1.1, this will be WAN1, its config will be as follows:
WAN Port: WAN1
WAN Connection type: Static IP
IP Address: 192.168.1.2
Subnet Mask : 255.255.255.0
Defult Gateway: 192.168.1.1
MTU Size : 1500
Pri DNS: (add the DNS here)
Sec DNS : (add the DNS here)
the second line shuld be the same way with difrent IP & difrent subnet (for example IP=192.168.2.2, Subnet Mask = 255.255.255.0 - for the router connected to the 2nd line IP 192.168.2.1 which will be the defult gatteway for WAN2)
hope this answers your question
Hosean Kobara
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
