American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
Gary Williams Posted on Mar 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Thumping in the kitchen water lines - American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
Strnj1
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on Mar 09, 2014
Strnj1
Expert
Level 2:
Sergeant:
Answers
239
Questions
0
Helped
48792
Points
624
You have a water valve or back-flow preventer slamming closed, somewhere...
We have Maytag washer- new- model #MVWB765FW3. There is a thump from the hot water connection on the wall every time washer fills. I'm wary of water hammer. Is this something to be concerned about?
Yes, the thump is water hammer caused by the solenoid shutoff valve in the washer closing abruptly when the tub is full. Water hammer stresses the piping joints and could eventually cause a leak. First, make sure that the piping is supported properly to restrain any excessive movement. If the thumping persists, you'll need a plumber to install an accumulator or 'dead end' pipe in the line to help dampen the shock of suddenly stopping the flow of water.
2helpful
2answers
I have a glaicer bay kitchen faucet and when the water is turned on there is thumping. When I take the sprayer off the thumping stops.... is therea probelm with the sprayer?
to reduce the 'thumping' noise, open the supply valves more. If they are already at maximum, you may have a restriction further up the supply lines. Thumping is typically caused by unbalanced flow around the seat and washer, usually caused by restrictions.
1helpful
Brand new faucet thumps when turning on
you have air in line
1. turn off water under sink
2 turn faucet on full
3. turn on valves under sink water will sputter then run solid
Hope this helps mike
1helpful
My kenmore coldspot refrigerator sounds like it is backfiring. Air in the line?
If it is the water line you speak of the I would just let the water flow until the lines are clear. Otherwise I would be looking at the fan motors mocking the noise. There is no possible way for air to get into the refrigeration lines. Good luck
5helpful
I just bought a new Delta kitchen faucet, it is a two handle, sprayer model. It makes a thumping noise when I first turn the water on and when I use the sprayer . I've been told to replace the diverter....
The thump comes from one of several areas. Air pressure in the hand sprayer is one.
But I suspect that you need to check your shut off valves. Old style (non ball) valves fail during this event. There is a little washer that deteriorates, over time....
Then you need to install a faucet, you shut the valves and the little washers either break or come loose. When they break, little pieces go up and clog the faucet.
The other failure is they partially block flow afer coming loose, and cause a thump, like what you describe. To fix, shut off main water in the house and DRAIN what you can. Best to replace with whole new valve, but next best is to replace the guts, unscrew and take to hardware store and get new stem and guts. Inspect the seat, often they get damaged and pitted. Nor necessarily an issue on this install, as the valve in normally open...
Oct 17, 2010 • Delta Home
Hi the shower has just started to pulse and thump when using the hot water. Could you please tell me what is wrong. Thnk you. Ellis
your hot water causing a thumping is just built up air in the line, you can install a devise for this ,, also,, make sure your water lines are strapped down ,,
Aug 02, 2010 • Home
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Smell in kitchen water
Is your supply line plastic or copper? If its plastic then that can absorb a smell. There is nothing in the icemaker that would make it smell. You may need to replace the supply line and the inlet line that feeds the icemaker. Is there a smell in the kitchen faucett?
1helpful
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Top American Standard Plumbing Experts
john h
Paul Carew
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
