HP Photosmart C5180 All-In-One InkJet Printer Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink system failure & keeps shutting down & coming on its own.
At first, the Photosmart gave me ink system failure and now it keeps shutting down and restarting. Once it restarts, it tells me I have shut down the printer wrong. It restarts and then shuts down again and again until I unplug it from the computer
JDTec
Level 3:
  • HP Master 4,338 Answers
  • Posted on Jun 12, 2009
JDTec
HP Master
Level 3:
Answers
4338
Questions
0
Helped
2127836
Points
14653
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
  • Anonymous Feb 01, 2012
    Thank you Joe Diaz .HP told me to recycle printer and buy another one!
8helpful
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
2helpful
3answers
Printer wont print there is a message that says ink system failure please "turn system off and then on 0xc19a0036" we have done this many times but it is still failing to work. what to do?
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
3helpful
Hi i got a Hp photosmart 3100 Series and its not
Hi there
Solution 1:
- Hold down the "OK", "Cancel", "Black", and "Color" buttons at the same time and turn the printer off.
- Keep holding the buttons down until the printer shuts off and turn it back on.
- Turn the printer off twice and then it will recalibrate.
- Make sure there are new cartridges in the printer so that it can reset.
Solution 2:
- Remove the cartridges from the product.
- Wait for the 'Insert Cartridges ' message to display on the control panel.
- Disconnect the power cord from the back of the product.
- Wait 60 seconds.
- Reconnect the power cord. If the product does not automatically turn on, press the Power button.
- Reinsert the cartridges, and then close any open doors on the product.
- If you receive a prompt to print a calibration page, do so.
- Reconnect the USB cable to the rear of the product, and then try printing again.
1helpful
I am getting an error message on my HP Photosmart 3310 as per below: INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013...
Hi
HP Photosmart C6180 All- In- One Printer "ink system failure"
hELLO PLEASE TRY
4helpful
5answers
Ink system failure
Turning the printer on and off will not solve your problem. If you get ink system failure you most likely have air in your ink system. This will happen after months of use -every ink cartridge you reload and purge will have a little bit of air trapped in it and over time it must add up. You have to do a system reset which causes your printer to start over and do a full purge of ink through your system. This is what happens when you do your first ink system set up when you open install new ink cartridges. To do a ink system reset you must first:
1. After your printer gives you a ink system failure you will need to press and hold down ok and cancel at the same time and then press the start button once. (make sure you hold the cancel and ok down until the system shuts down and then release).
2.Now (Again) hold the cancel and ok Button down and and press the on button again -making sure to keep holding down the cancel and ok until it shuts itself down again. It will seem like it is starting up again up will then just shut off. Now once it has shut off for the second time (It is VERY important that you have a new set of ink cartridges installed before turning on the system for the second time) This is because it will do a full ink purge and rid the trapped air in the system. If you have old ink in it or almost empty it will most likely not purge enough. A new set of ink works best- You can go back to your old ink after if you like and keep the "new" set for back up when the system fails again down the road (it will fail again -this is poor designing by HP).
3.Now once you have shut down the system and loaded a fresh set of ink (all 6 of the ink cartriges) you can now press the on button (at this time you should get a reset code the come on first and the printer will run its purging of the air and new ink.
4. You might have to do this more then once to rid all the air out of the system-keep trying and after 2 -3 times it will stop giving you the ink failure. I have fixed my printer many times by this fix for many years.
Good Luck!
k24674
Grand Canyon Tech
Grand Canyon Tech
