Question about Proform Crosswalk 395 Treadmill
Belt keeps sliding from side to side
Ordered new walking belt, put on made adjustments with hex wrench but still slips from side to side after numerous adjustments. What am I doing wrong. New belt is starting to frey on one side.
    Top Expert:
  • 2,044 Answers
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
Posted on Mar 03, 2014
Testimonial: "belt is brand new. Did what you said but belt still keeps sliding from side to side. Any other possible fix?"
  • Todd Arndt
    Todd Arndt Mar 10, 2014
    If you pull the belt all the way back and you are adjusting it correctly, then you have a belt that is too long or the wrong belt.
SOURCE:
  • 103 Answers
SOURCE: my treadmill belt keeps slipping when i put my
more than likely the drive belt needs to be tightened. This is done by removing the lower cover. Should be 2 screws in the rear and 2 screws on the bottom to remove it. Then there is an adjustable bracket on the motor. Hope this helps, Tim
also a pdf manual can be found on iconservice.com for free download.
Posted on Nov 13, 2009
  • 103 Answers
SOURCE: my weslo cadence 200 treadmill belt keeps slipping
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Posted on Nov 25, 2009
  • 13 Answers
SOURCE: Proform Crosswalk Advanced 525X
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
Posted on Dec 01, 2009
  • 15 Answers
SOURCE: The belt on my treadmill keeps slipping/moving to
At the back of the treadmill, there are 2 adjustment screws, 1 on each side. They are used to move each end of the rear roller either forwards or backwards. I typically teach people to use the left hand adjustment screw because the direction you turn the screw is the direction the treadbelt will move. Turn the machine on and run it at the lowest speed, usually .5mph and while it's running, make an slight adjustment. If it's running while you do it, you will be able to watch the progress of the belt and it's easier to fine tune it this way. Using an allen key (you should have been supplied one with the machine) turn the adjustment bolt a 1/4 turn in the direction you want the belt to go (only from the left). Wait a few minutes and watch it carefully, you do not want it to run up against the side rails of the machine, this will shred the sides of the belt. You really shouldn't need to turn it more than a 1/4-1/2 turn to make an adjustment. Watch the belt migrate back towards the center and when it gets close, turn the screw slightly back a bit to stop the progress, or it will stop on it's own as it reaches the higher angle of the roller. Patience is key here, don't try to do it one morning on your way out to work. Give yourself 15-20min to focus on it and remember that as long as you don't use large adjustment increments and pay attention to where the belt is headed, you'll be fine.
Posted on Jun 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: when walking on my pro form xp weight loss 620,
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on Jul 20, 2010
How do I change the walking belt on a Nordic Track EXP 2000?
First, remove the motor hood. There are 3 screws at the front, and 2 underneath. The screws underneath will have to be removed by tipping the treadmill over, or pulling the console towards the rear of the machine.
Next, remove the side rails. This is a little tricky because of the cushion adjusters on each side of the deck. If you look underneath the deck, you will see that the adjusters are on rails that are attached to the platform. Remove all of the screws from the side rail and push it toward the rear of the machine while also moving the adjusters rearward. You'll have to kind of move them together until the adjuster slides off the rail. Do both sides.
Remove the rear roller, by loosening the bolts. Don't mess with the front roller unless you intend to replace the motor belt. You don't need to remove the front roller or the walking belt.
There are 4 bolts holding the deck to the frame. The rear ones go through the frame to a lock nut. The front bolts screw into the isolators. Remove them and the deck will come loose. You can slide it out from the walking belt.
Place the new deck next to the old, and start moving the parts over. Make sure the safety decal is on the bottom like the old deck. All of the holes are pre-drilled except for the belt guides. You'll have to measure for these. Now do everything in reverse to reassemble the machine. I'm also attaching instructions on how to adjust the belt.
First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it's the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can't find it, a standard (not metric) allen wrench kit will work. It's helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you're tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn't necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I'm showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
The above instructions is a generic one for this series. A slight adjustment might be required.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 01, 2010 | Exercise & Fitness
Track sliping
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.If slipping feel persists after several adjustments, stop and see if it maybe the drive belt. Remove left rear plastic cover to expose “v” belt drive line and motor. Tighten nut on the motor tension bolt located on front side of motor in 1/2 turn increments until drive belt slippage is eliminated - DO NOT OVER TIGHTEN. Replace cover when finished.
Jun 27, 2010 | Bowflex Treadclimber
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
May 22, 2010 | Bowflex Treadclimber
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
C2200 belt is slipping how to straighten and tighen belt
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
Good Luck!
Mar 11, 2010 | Nordic Track /proform Treadmill...
When running the belt is jerky and feels like it slips a bit Dan
Good Luck!
Mar 06, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
I am having problem with the belt moving when i am trying to walk/run on treadmill
Good Luck!
Mar 04, 2010 | Proform 760 CrossTrainer Treadmill
My nordic track c2000 apears to start working but then the belt stops, if i step off belt it starts working again
Good Luck!
Mar 03, 2010 | NordicTrack Exercise & Fitness
How do you replace the walking platform on the Nordic Track A2250 Treadmill?
Good Luck!
Mar 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Walking belt on image 10.0 tread mill slips, purchased it used, can see where it has rubbed to the left. How to adjust it?
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Feb 25, 2010 | Exercise & Fitness
Proform Crosswalk 395 Treadmill Logo
221 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Android Man
Android Man
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
