Motorcycles Logo
E
Emir YILDIRGAN Posted on Mar 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Beret 2 way 5000m alarm siren problem.
Hello. i have a problem. I bought and installed an alarm on my honda cbr250r motorcycle. Alarm is working. Then i switch silent mode and then and i want to get to the normal mode but does not switch to normal mode. Alarm always silent mode. Remote control is showing on the normal mode but i can not hear the siren sound. I set an alarm on and only signal lights and remote control sounds but not work siren sound. How can i reset this alarm ? I remove the battery cables and re attach the cables but problem did not improve. Maybe siren broken ? How do i use the siren again ?
Todd Arndt
Level 3:
Top Expert:
  • Motorcycles Master 2,044 Answers
  • Posted on Mar 03, 2014
Todd Arndt
Motorcycles Master
Level 3:
Top Expert:
Answers
2044
Questions
Helped
583769
Points
5934
These Alarms are so very fickle. If the Alarm lasted a year, then you are out of warranty and I have removed more than my fair share of Alarm's. As the Vehicle owner, you need to realize that your problem is quite common and you should be grateful it has not complete immobilized your bike. My Recommendation is... Remove it and return it to Stock or spend the money and get a higher quality alarm with a great reputation. Don't truck the Install Shop, they get tied to one brand, find the Alarm that meets YOUR NEEDS...
Testimonial: "thanks for your comment. I'll try to return. But i do not think I'd be able to return. Because i bought it on eBay..."
  • Todd Arndt
    Todd Arndt Mar 03, 2014
    There are multiple people who have posted Issues with these particular Alarms... Good Luck
3 Related Answers
OneRide
Gar
  • 384 Answers
  • Posted on Oct 10, 2009
SOURCE: Just installed smart siren kit, worked ok for 1
Harley alarms, while a decent alarm system, are notoriously hard to set up. On a new installation I have sometimes had to run the set-up routine 4-5 times. I hope you have an owner's manual and/or good instructions. Keep trying to set the alarm up from the beginning. If you miss a key or time limit it's not unusual to have the set-up fail and you have to start all over. Disconnecting the battery will screw things up, so be careful.
Anonymous
  • Posted on Mar 20, 2012
SOURCE: How can the sensitivity of
I actually manage to change the sensitivities, press disarm button 3 times and arm button 3 times, do it until you hear 1 or 2 bips - it is the highest sensitivity.Take a look at this site to i will post a video in menu - special content- special video on the bottom of www.cool.homepagepays.com
Anonymous
  • Posted on Jun 16, 2012
SOURCE: remote starter not working
it is probably too late
Deactivate alarm on soft ail
For the alarm siren deacrivate the alarm with fob or pin and then locate the siren under the splash guard in front of the rear tire and unplug it.
Honda goldwing alarm won't turn off
There should be an alarm siren module with batteries in it, those batteries are most likely bad or failing. OR theres a "trigger switch" usually like a button that triggers the alarm and it could be stuck open or closed. a small amount of lube on this button will take carre of it
Hi. i have a problem.I bought a new alarm beret 2 way 5000m and setup on my motorcycle. Alarm is working. Then i did switch to silent mode and now back to normal mode does not. Alarm always work silent...
If the Remote is now working now, the problems in the future will continue and get worse. I would recommend removing it and returning it for a Higher Quality Alarm System
Mar 03, 2014 • Motorcycles
How do I uninstall an Audivox 6 tone mini siren from my 2004 Honda Accord. I didn't install this item and now it is always arming itself locking me out of the vehicle!
The siren is merely the part of the alarm that gives you an audible alert when you arm, disarm the alarm. It also alerts you to intrusion and tampering. The siren does not arm itself and lock you out.
Locate your valet switch and turn the ignition on, press and hold the valet switch, count to five and release. the unit will be in valet at this point. Locate the model number and report back for the instructions to disable the passive arming.
1helpful
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
