Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
A
Anonymous Posted on Mar 03, 2014
Won't hold charge - Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
Jack Fairbrother
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 53 Answers
  • Posted on Feb 11, 2015
Jack Fairbrother
Contributor
Level 1:
New Friend:
Night Owl:
Answers
53
Questions
Helped
12680
Points
62
Time for new batteries.
2answers
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Battery won t hold charge
If your battery does not hold charge, and you don't want to buy a replacement, then there is not much can do other than to keep using your laptop with the charger. All batteries have a time life span.
1helpful
Will not hold charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
1992 Mazda mpv . Won't hold charge . Engine won't
The first thing to do is have the battery tested, just because you charged it doesn't mean it will stay charged if the cells are sulfated up or shorted.
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
2answers
Sony vaio vgn-nr285E battery won't hold a charge
2helpful
It worked for a while and I was able to recharge it, but now it won't hold a charge.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 01, 2011 • Cell Phones
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
