If the machine is beeping or there is an error message, the machine is malfunctioning somewhere--could be the machine or the operator has not setup the machine properly.. Consult the owner's manual Troubleshooting section for possible resolutions to your issue.
Thank you for your help . My buttonhole lever wasn't down all the way and resulted in C2 error.
I do not have a fancy Brother machine. From what I understand, you just need to do a zig-zag stitch around the "rectangle" that will become the button hole.
You could forego whatever instructions they provide and just set your stitch width as appropriate and then move the stitch type to a thin (close together stitching) zig-zag, just shy of "satin stitch" (which is just sewing back and forth all in the same place, and therefore--useful for embroidery).
Sometimes easy does it can be the ONLY way to get things done. :) Sorry I don't know more about your specific issue but maybe the old school way will help.
SOURCE: One step button Hole V for Singer Sewing Machine
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
SOURCE: Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual.
1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
