Question about Jeanie Rub Health & Beauty
Motor bogs down when pressure is applied - Jeanie Rub Health & Beauty
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
What is an uploader
I think you mean an UN Loader this is a valve that redirects (bypasses) the pressureized water back into the intake when you release the trigger When it is not working the machine continues to build pressure and will bog down
hope this helps
the ed
Oct 08, 2015 | Northstar Garden
Idles but bogs down with a load
How about a defective fuel pressure regulator, buy a fuel pressure test gauage from Autozone and test the fuel pressure under a load and at idle..
Sep 17, 2012 | 1988 Dodge D-Series Pickups
My 1995 Pontiac firebird (3.4L V-6 Automatic) sputters when load is applied to the motor (slow acceleration) between 1500 and 2200RPM. Above 2200 rpm the car does not bog much at all. From a take off at...
Check fuel pressure regulator for fuel laying in the vacuum line going to the regulator.If it has fuel in it replace regulator. If its ok then check fuel pressure if its not within specs replace pump.
Apr 26, 2011 | Pontiac Firebird Cars & Trucks
Unit slows down ,bogs down
check the belts , if there not lose then the incoming power could be low or the motor could be going bad.
Apr 19, 2010 | Ingersoll Rand - Rand Type - 30...
89 laredo 4.0 Starts, Idles but no power
Have you checked the fuel pressure while pressing the gas pedal? Pressure should stay above 40PSI
Jul 13, 2009 | 1989 Jeep Cherokee
I have a 1992 suburban 350 motor. truck had no power and bogged down when gas pedal applied. i changed the filter and now it wont start by itself. i spray starter fluid and it runs fine for 1/2 hour then...
first thing i would do i would check fuel pressure if you have good fuel pressure then the next thing i would unbolt the exhaust from the exhaust manafold and then try to start engine if the engine starts up and runs fine then you have clogged up exhaust converters
terry - Master tech
Jun 18, 2009 | 1992 Chevrolet Suburban
Brand new Husky 60 gal 3.2 hp runs to 30 psi and then starts bogging down and running and bogging down ect. No more pressure over 30psi and i can hear on and off clicking of the motor. Did I wire it wrong...
SOUNDS LIKE IT WIRED FOR 220VOLTS AND YOU HAVE IT PLUGGED INTO 110VOLTS. IF THE MOTOR SAYS 110/220 THEN FOLLOW THE DIAGRAM FOR LOW OR HIGH VOLTAGE. MAKE SURE CORD IS ADEQUATE SIZE. HOPE THIS HELPS.
Apr 25, 2009 | Campbell Hausfeld Air Tools & Compressors
Motor bogs down at stoplight when pushin gas pedal
The fuel pump relay will cause a stalling or no start condition. You are likely having mass airflow sensor, fuel pump, or fuel pressure regulator issues.
Bret
RepairPal.com
Nov 08, 2008 | 1985 Volvo 740
96 pontiac sunfire bogs down and dies when I apply the gas.
as far as the bogging and dieing,it sounds like the tps.a simple trottle body service would fix that.for your new problem you need to some test before pointing to a salution.start the car and cover your tail pipe.as pressure builds it push you hand off.a clogged cat will put to much back pressure on the engine.i would un plug the mass air flow sensor and try running the car.this will turn on the check engine light.check your air filtter and plugs.also check your wires.a nother test is a coil strees test.(you have to go to a shop for this)if the car runs ok with no load but spitts and sputters in drive you may have a openning coil.checking with a meter only works if it does not run.last but not least while you at the shop,have them check your timing.a faulty cam sencer will bog the car down with bad timing advancement but not throw a code.
hope this helps,remember to keep it simple,expensive elec. parts are not always the problem
Jul 07, 2008 | 1996 Pontiac Sunfire
Health & Beauty Logo
82 people viewed this question
Top Jeanie Rub Health & Beauty Experts
Colin Stickland
Colin Stickland
Bill Boyd
Jeff Tilburn
Jeff Tilburn
Are you a Jeanie Rub Health and Beauty Expert? Answer questions, earn points and help others
