Quite often there is a label on the bottom and this hides a screw which holds the mouse together. If there is a label on the bottom, try rubbing your finger over it to see if you can feel a hole underneath. Also on the bottom are plastic glide pads which help the mouse to move freely. If there is a large one towards the back then it may also hide a screw. Use a thin blade to lift off the glide pad and hopefully the sticky layer will remain sticky to make it easier to put back.
I had same problem. Go to the hardware store and buy some Velcro strips. One side has adhesive, just put that side on the mouse. I had to put several strips on then cut around the shape of the mouse. Sandpaper for the mouse sticks to it great. Just be careful when pulling the used sandpaper back off that you don't tear off the Velcro. I threw that little pad away that was originally on the mouse.
press the fn key and the f key ( ie f1 f2 f3 ect ) together, cant remember which f key it is and one of them will work, they are called sticky keys. hope this helps.
Search for out other postings here at FixYa. The sticky situation is one I had, but it was the actual wear inside the mouse buttons to microswitch contacts. I would have to click numerous times to get my mouse to function. The plastic pads get worn after some intense use. Check for our solutions here in other postings.
