Paper jam I suppose is the commonest of all printer problems as it can
occur due to strayed, stuck bits of papers in pathway of paper tray,
outlet, roller etc. I would recommend cleaning the paper inlet, outlet,
and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you
locate the jam. You will find it either in front, near the paper tray,
or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull
it firmly but gently from the printer. If you find a stack of papers
jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the
printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at
http://www.vtechsquad.com/
