are u saying it shuts down or just stops heating? if it shuts down u may have bad motor windings and or brushes and motor is burning out if its stops heating that is usually due to bad moister sensor, cycling thermostat ( which would not usually shut appliance off though), short in heating element, defective hi limit thermostat etc and of course u already said u cleaned lint and ducts? including the blower? if its blocked with lint u have a shut off issue
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
If no heat then likely the element. However if it gets hot and then heat shuts off, you could have a defective humidity sensor or blockage in the lint trap or vent pipe if it is warm but never finishes it`s cycle,.
check and make sure it has a clear clean vent.no kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
Try this and let me know what happens.
TIP OF THE DAY To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
