Same problem as was already posted. My Whirlpool Quiet Partner dishwasher will fill with water, heat the water, but then doesn't run the wash cycle, no spinning or spraying. We noticed the unit was getting louder during the wash cycle which leads me to think a drive belt was slipping (if there is one), or the motor bearings are shot. I'd like to try fixing it myself, but would like to know where to start. Any suggestions and a downloadable schematic would be great.
Thanks,
Lance
To tell you the truth, I don't even know what model my Whirlpool is. However, I had this same issue. My dishwasher would fill, but it wouldn't spray the water. I could hear it hum, but the motor wasn't going.
After no success finding any ideas online, I had to call out the repairman. Well, 5 minutes and $109 later it was just a simple matter of the motor being stuck. Apparently this is a common issue with GE, but not as common with Whirlpool. Just a seal that gets stuck if you don't use it for awhile (even though there hadn't been any long stretch for me). He reached in/under and turned the motor a bit over a half rotation before it broke loose. It fired up... I wrote the check ... and he left.
He advised me to run the washer on the rinse cycle at least once a week.
Hope that helps someone.
I removed the bottom cover, make sure that the dishwater was off, turned to motor blade with a screwdriver clockwise (I saw an arrow and figured that that was the direction to turn the blade). After a small tug, the motor then moved freely). Powered the dishwasher and it worked like a charm.
I disassembled the bottom spray arm assembly to find a piece of chicken bone wedged against the motor gear. There was also lots of food debris lodged in every crevasse One main hole in the spay arm had paper lodged in it. So it was beneficial to do the extensive cleaning.
The dishwasher fired right up after I put all pieces back together.
DU945PWPB2 Whirlpool dishwasher won't start. The light for "Normal" wash comes on but the "start" light won't come on and the washer won't run. I have replaced the thermal switch already and it didn't fix the problem. Any suggestions?
