I'm trying to print wood tones on laser waterslide paper. On two prints they came out correctly on three others the browns turned to oranges.
SOURCE: Problem printing 1m long paper on 7760
http://www.kingswaytechnology.com.au/pdf/indesigncustompageosx.pdf
Go to this link, it is for a Different docuprint model, but the setup should be the same. Also Set to thin card stock, will stop your fusing problem, and use standard print mode, unless you have 1GB RAM in the printer.
SOURCE: It looks like it's ghosting - shadows
Most likely the fuser needs replaced. The heat roller is worn and causing reprint.
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
SOURCE: 7760 DN printing crooked from tray 5
7760 dn solo tiene dos trays...
entiendo q la tray 5 sera el by-pass or left tray
la ultima vez q me paso eso es pq hicieron etiquetas q dejaron residuos de cola en el bafle de los rodillos de partida del by-pass, el papel se frenaba por el lado in y torcia el papel
SOURCE: I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
The CE Access Number screen will appear.
WC73XX only: Select a paper size and type using the paper supply button
