I NEED THE VALUES OF CAPACITORS TO REPLACE
Those values are printed on the side of the capacitors. You can tell which ones need replaced by their bulging tops.
Testimonial: "Yes but the glue between capacitor make impossible the riding of values first move the capacitor and after cleaning found the values replace all power supply capacitor with bigger value of volts and no problem ..."
hi, to replace the capacitors need to take the board out, by removing the screws and disconnecting the wires braids. You need bread, tin and absorbs tin. You should take the tin from the legs of the capacitors, until it can release the capacitors outside the board. Next, you put the new capacitors in place. Should pay attention to put the capacitors, by proper polarity of plus or minus. It is important to be precise with the value of capacity and try to put a capacitor with a value of slightly higher voltage, temperature resistant to 105 degrees.
