Hi my defy f640 side by side have been giving me endless problems the red light comes on and the freezer does not freeze at all.
The red light that comes on and the freezer not freezing could indicate a few possible issues:
Temperature setting: Check to make sure that the temperature setting in the freezer is set correctly. If the temperature is set too high, the freezer may not freeze properly.
Thermostat: The thermostat may be malfunctioning, which can cause the freezer to stop freezing. You may need to have it replaced.
Evaporator fan: If the evaporator fan is not working, it can cause the freezer to stop freezing. You can check to see if the fan is running by listening for it or feeling for air flow in the freezer. If it's not running, it may need to be replaced.
Condenser coils: Dirty or clogged condenser coils can cause the freezer to stop freezing. You can clean the coils with a vacuum or brush.
If you've tried all of these troubleshooting steps and the problem persists, it may be best to contact a professional technician to diagnose and repair the issue.
