When the power was given the lamp was not working, it shows green light for very few seconds and turn to red and blinking. how to over come this problem? is there any protector on the circuit? where is it located? please reply me..
SOURCE: Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
SOURCE: lamp will not come on. Press power button, fan
You might not be getting power from the ballast, it may be gone.The ballast is what gives the lamp it's major charge of high power.
SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Testimonial: "Thanks! And please tell me where is the lamp cover located."
SOURCE: when i turn the power
try the lamp cover and filter cover interlock switches are working and the covers are secure
SOURCE: VPL-HS50 shuts down after few seconds
It must be a problem with electric connection. you should check whether it is OK or not. If it is okay, read instruction manual.
it was flashing more than 3 times.
