I don't know a whole lot,but I believe you need more voltage,higher ah,and make sure the resistor can handle it.Replace the motor.Look it up at www.monterbatteries.com :)
You can try changing the MTU size on the router to 1365. Open the setup page of the router. On the setup page you will see MTU, change it to manual and change the size to 1365. Save the settings and power cycle the router.
You can also try to upgrade the firmware on the router. After upgrading the firmware on the router, reset the router and reconfigure it.
I want to upgrade my powerbook G4 :
processor 400 MHz Power PC G4
Memory 256 MB SDRAM
L2 Cache (perCPU) 1MB
Bus Speed: 100 MHz
I'm looking to upgrade memory and speed !!!
You can also switch your power settings to performance, Which wouldn't use the CPU's built in speed step. Speed step lowers the CPU's clock speed when not in use.
But this also uses more battery since the CPU's continuallyrunning at full speed at all times.
This sounds like the modem is not made to handle the speed that you are looking for. When you upgrade speeds on your internet connection you sometimes will need to upgrade the router
First check if you are able to print self test page faster or at the same speed.
If you are able to print self test page faster than you need to check for drivers and incase if self test page is at the same speed than you can try upgrading firmware of the printer.
As you havn't mentioned the exact speed i cannot confirmed whether printer will speed up or not.
If the printer is already printing at the designed speed than upgrading the firmware will not help.
However upgrading the firmware is always advisable.
Please upgrade the firmware using the link below :
Your CPU speed depends on your front side bus speed. Overclock is an option but never recommended. The upgrading ram is cheapest and most noticable upgrade you can do. If your do want to upgrade your computer i would recommend upgrading ram. Remember any computer with a 32-bit processor can only reconize 4 gig's of ram.
