Mitsubishi 1997 GALANT Radio a1z106836 receiver, AM-FM-cassette, w Logo
Rob Kwisi Posted on Mar 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rough idle after engine starts idle is high after 5 minutes engine runs rough ,high and low for 5 minutes then stall .when start engine again , it repeat same process again. the engine runs rough and high on stops .when drive ,can feel car runs rough and shaking . when change gear , no need to step on speed petal cause engine speed is high
Christian Krentz
Level 3:
  • Mitsubishi Master 694 Answers
  • Posted on Mar 02, 2014
Christian Krentz
Mitsubishi Master
Level 3:
Answers
694
Questions
Helped
159975
Points
1404
Poss mass air flow sensor
I am having serious problems with the idle modual it reves at the norm then all of a sudden the reves just increase up to roughly 2.300 and then come down to near stalling
First Check All Air hoses. Make sure no vacuum leak are present.
make sure your ignition coil are good. This will make engine idle roughly. For the rpm to high or to low maybe your air idler is no good. If you're car turn off it might be overheated. Check coolant level. Make your not mixing water with oil. Check the oil dipstick to verify. If like a milky color then it's mixing water with oil. This will car to stall and run roughly
2answers
1helpful
2answers
92 dodge 1500 pick up 360 v8 automatic Starts, runs but hesitates, low power code 37 on diagnostic readour
Code 37 is torque converter clutch solenoid failure. Transmission wont shift in and out of overdrive.
I have a 2000 ford explorer sport 4.0L OHV, in the mornings when first started it runs real rough until it goes through its cycle of runing rough then it cleats up and runs ok. Then when u park it after...
Here are the most common causes of idle surge, rough idle esp when cold, other symptoms include stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
I have mercury villager 1999 ,when started in morning idler ok , after run for 20 mnts engine stall in idler turn off ,end stared back up ok give gas go normal , and star again idler low like lose power...
Read the following and follow the instructions for this problem.
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
3helpful
When i start my 1997 Geo Metro, it often sputters
Try this
Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation, it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
13helpful
Car idles low, stalls after start
Common issue at the shop (i'm a ford technician), here is what I do to correct it.
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Starts but stalls when put in gear
Here is the most common cause of surges and stalls and low idle rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
2helpful
2000 isuzu 3.2 rodeo
1helpful
Engine turns off when coming to a stop
I have used this procedure for years.
Top Mitsubishi Audio Players & Recorders Experts
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
