TCL L32HDM11 32 Class Widescreen LCD HDTV - 720p, 1366 x 768, 16:9, 30 Logo
A
Anonymous Posted on Mar 02, 2014
Screen has blacked out no picture
Have sound on t v no picture does this meet the picture tube has gone
1helpful
Is my picture tube gone in my seiki hd tv because i can hear sound but i cant see a picture
These TVs do not have a tube, You get tubes in CRT TVs only!
It could be the backlight screen inverter PCB has gone, to test if you shine a torch light at the screen with the TV on and can see a faint picture then it is probably the inverter.
Hisense 50in hd tv has no picture but has sound
Sounds like either the CCFL tube (like a mini florescent tube) or the inverter that powers it has blown.
When i turn tv on it gives me a picture for 1 second then goes blank, we still have sound
Hello
Sounds like you have lost video somewhere in the video circuits. Possibly the picture tube could have gone bad or lost filiament voltage.
You can check to see if you have high voltage by holding your bare arm close to the screen. The hairs will stand up if you have high voltage. Absence of high voltage will also cause a black screen,but the sound might not work either since on some sets the power for the sound is supplied from the same circuit as
the high voltage.
Goodluck
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
No picture or sound. Buzzing coming from where
Ur high voltage is dead.The FBT the Flyback transformer not prodeucing high voltage.The big black block of plastic with a red wire with a cap hook to the CRT(tv tube).The FBT,must replaced to solved this problem.
Problems
it sounds like a resistor has gone bad that controls the tubes for the picture.you might want to call a service tech in and have it fixed,
Black screen
when problems occures with monitor is always with picture tube but some time less brightness is also reason for black screen
check brightness of your system i think it should be on maximum level and brightness is perfact so i said problem with picture tube. may be picture tube is gone...
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
1helpful
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
