TP-LINK TD-W8901G Router Logo
A
Anonymous Posted on Mar 01, 2014
Hard reset 30
Only power buttom is lighing
1helpful
How to hard reset a WM8880 laptop
Power the unit off (holding power buttom) and selecting Power off, then simultaneously hold the "back" button and on button for about 8 seconds. When the android icon appears, press back buttom, in the menu select wipe data/factory reset pressing the home buttom and then press the back buttom, in the next screen select "yes delete all user data" pressing back buttom, and in the next screen select "reboot system now" with the back buttom and wait.
22helpful
2answers
E15 sony ericsson pattern locks problem how to hard reset moble by buttom
how can i open my phone sony ericsson pattern locks problem how to hard reset moble by buttom
2answers
My Motorola Blur Wont Turn On
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
5helpful
2answers
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Front panel 10 pair motherboard plug in configuration
this will do
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
PUT IN NEW BULB EVENTUALLY GOT A PICTURE LAST NIT RESET BULB LIFE GOT UP THIS MORNING STARTED OFF WITH A PICTURE SLOWLY STARTED TO LOSE PICTURE AND NOW JUST LINES DOWN THE SCREEN NO PICTURE
try to rest the tv by unplug from outlet press power hold it them reconnect power cord while you hold the power buttom on tv for 30 seconds them release and do the same with cable box.
2answers
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
I used the router ip but log in page is not displayed,status ligh is off,
First thing to do here is to reset the router, To reset it press and hold the reset button for 30 seconds while power is ON then after that unplug the power for 10 seconds and then plug it back in hopefully you can now access the router setup page again, but if still the same router is already bad and needs replacement....
4helpful
I can`t make a hard reset to my cellphone, I want to try making a hard reset because the problem is that i can`t open some aplications like phone, contacts, tasks, calendar. mys friend tolds me that i...
Hard Reset Hold down the Power button (Top Right corner) and at the same time put your Stylus pen in the hole where it says “Reset” (Lower Left corner).
Hard Reset will delete all data you have put on the device, Programs, Settings, Mail, SMS, MMS, etc., so be careful and make a backup before doing this.
After a hard reset, you will have a complete clean new install of Windows Mobile on your device.
Things that are not deleted
  • Data on \Storage Card
  • Data in \Storage folder
No sound no picture
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Top TP-LINK Computers & Internet Experts
 Mikey
Mikey
Menachem Grossman
Menachem Grossman
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
