I have a Frigidaire Professional Series Range. MOD.PLES389ECE. Whenever I try to turn on the oven or clean it, I get the F30 ERR message. The clock, timer, and stovetop work fine. I ordered a new temp probe from Sears and installed but I still get the message. Techs around here say I need a new computer but it is non-refundable so I want to make sure before I order.
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
any luck?
Having the same error message on our PLES389ECE. We've replaced the probe and the motherboard. Even tried a second motherboard because we were told ithe new one had to be bad. The stovetop works fine. The clock will count up from 12:00 each time we reset it, but will not let us set correct time. Any ideas?
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. If you have already changed the sensor, I suggest checking the wiring or contacting a professional to move forward accurately. You can try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, once again contact a professional to properly diagnose the unit.
