To pair a Samsung remote model AK5900104R2A with a Philips DVD player model 714821 2001, you will need to first locate the Philips DVD player's remote code. You can find this code in the instruction manual, or by contacting Philips customer service. Once you have the code, press the "Setup" button on the Samsung remote and enter the Philips DVD player's remote code. If the code is accepted, the Samsung remote should now be paired with the Philips DVD player.
Here is the list with the KNOWN working device codes for Samsung Blu-Ray DVD players. These should work with ANY remote as these remote codes are universal. Samsung Blu-Ray Player Universal Remote Codes (4 and 5 digit)
0199 12051 10812 10702 10060 20199 31868 10766 20573 11903 22069 11060 21075 20240 31295 31500 22329 22369 21470 22489 01877 21044 20820 10650 10814 22556 10178 20490 20045 01982 31304 20744
Below are instructions on How to Program your Samsung Blu-Ray Player to Control your TV.
Use Samsung Blu-Ray Remote Control To Control Your TV
Is this a universal replacement remote or the same one that came with your DVD player? If it is the same remote, you should be able to find programming information in the DVD player's owner manual. The link to your player is below. Find the Remote programming information in chapter 6.
I am asumeing that the remote is from your dvd recorder/player which you wish to use to control your tv?
Which is possible. please follow the link to Samsung support, there are step by step instructions on how to use your dvd remote to control your tv.
google for it ive found that over 99 percent of the questions on here about remote codes can be solved by googleing them simply type google search then in the search bar type for whatever remote you have it should give a bunch of listings for your particular remote find your remote then the codes should be there with reprogramming instructions
Instructions for programming your universal remote should be included in package with the device. Codes for many remotes can be found at InsigniaProducts.com. Just search for your model number, NS-PDP42.
Try pushing the "source" button on remote or on the TV. Wait about 5 seconds, if no picture, push again. Do this at least 6 times or until you get a picture. With each push, the TV will look for cable input, dvd input, etc. until it finds your cable signal.
Also make sure your cable/antenna is hooked up and working.
If that doesn't work, hold down the "enter" button for 10 seconds to reset the tv to original factory settings. Then follow the on-screen menu setup instructions.
