Question about Pelican Code Breaker for Playstation 2
Code Breaker V8.1 for PS2...how do I use codes beginning with P1?
All the codes work except those starting with P1. How do I use those codes?
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Please provide a unlock code for HUAWEI P1 ASCEND
You can get the unlock code for Huawei P1 Ascend from Onlinegsmunlock.com .There you have to give your Country and current network name along with your IMEI number to get unlock code. They will give you unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Huawei P1 Ascend .
Apr 02, 2013 | Cell Phones
I am geting a P1 error code
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Rheem Tankless Hot Water Heater...
How to enter code for freelander 1998 Radio R770
Philips / R770 Rover Code Entry
Switch on the radio, the display will show 'C'
Press [P1] followed by the tuning button to rotate the first digit
Press [P1] followed by the tuning button to rotate the second digit
Press [P1] followed by the tuning button to rotate the third digit
Press [P1] followed by the tuning button to rotate the fourth digit
Finally if the correct code is shown on screen press the [P1] button to save the code.
Jan 10, 2010 | Car Audio & Video
P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Sep 04, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hi I have a Phillips R770 car stereo and the code for it but not the manual, can you tell me how to input the code into the radio.
Switch on the radio and the display will show 'C'. Press the P1 button followed by the station increment button until you reach the first code digit. Press P1 again and follow the above procedure until the last digit has been entered and finally press P1 once more. The set will emit a confirmation beep from the speaker and will begin to operate.
Dec 07, 2008 | Car Audio & Video
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Sep 13, 2008 | Danby DDR2506 Dehumidifier
P1 and P2 error codes
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Pelican Code Breaker for Playstation 2 Logo
57 people viewed this question
Top Pelican Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
