How to solve the problem IDC/Registration Sensor in konica minolta bizub c450
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
SOURCE: KONICA Minolta c450 in Windows Vista
go to the printers and faxes page and in the driver properties click on printing preferences click on authentcation/account track and you should be able to enter you name and password from there unless you may have to be logged on as the administrator on your computer to make these changes
SOURCE: Error code C-3505 Konica Minolta Bizub C6500
This is a fuser code, which needs reset by your service provider in service modes, let me
