In order to use your phone again, you will need to enter the email (Gmail) and password while connected to the internet via WiFi or data connection. If not, you will have to do a Factory Reset. Do the following to do a Factory Reset:
turn off the phone
press the following simultaneously:
Volume up
Power button
you will now be on recovery mode
(use volume buttons to navigate and power to choose)
Hold the power button down,until the phone reset s.It takes about 30 sec. Plus. If it didn't work plug it in to charge and the repeat the same step before you plugged it in. If that don't work then I am sorry it is time for a new phone.
iFixitiFixit - Alcatel One Touch Fierce Teardown: Tearing down a water damaged Alcatel One Touch Fierce from Metro PCS. ... It seemed to have quite a bit of adhesive. ... I have NO experience replacing a cell phone screen and this teardown ... I opened thephone and the little silver piece on the power button cable fell off.
What is covered by mobile phone warranty? ' Geek Squadwww.geeksquad.co.uk/.../What_is_covered_by_mobile_pho...Geek SquadOct 22, 2014 - A warranty is a manufacturer's guarantee to repair your phone or ...Alcatel, 12 Months, 6 Months .... "Does rooting my Android phone void the warranty?".... been dropped with enough force to break the small piece of glass!7 Practical Things You Should Do After Cracking Your ...www.makeuseof.com/.../7-practical-things-you-should-do-after-cracking...Jul 30, 2014 - Or, well, maybe you just accidentally cracked your phone's screen in a normal .... Id like to think that it protects my phone that little bit more.
could be a battery problem? or maybe the screen is gone?
if you have a warranty on it get it where you've bought it.
and they should either replace your smartphone, or fix the issue.
Easy. Press and hold the Power + Volume down buttons or Power + Home buttons at the same time until you see a flash on the screen which means the screenshot is successfully taken. If it still doesn't work on your phone, check here for more solutions. Different Ways to Make Alcatel One Touch Screenshot
Plug in with the 4030a's charger or the usb cable from a PC and it will power up. I'm having the same problem and this is now the only i'm able to turn it on aside from pressing and holding the power button hard for about 5 seconds or so
I'm having the exact same problem. An hour ago I was using my phone fine, and then it randomly shut off and turning it on again I have no touch function, while the volume and power are fine.
I've done everything recommended, much like you and having no luck :/
