Question about Leviton Electrical Supplies
Don't know the wiring diagram
I want to wire Leviton 16693 15-Amp, 120-Volt, Grounded, Compact Automatic gfci plug onto a 10/3 cord what wire goes where ?
  • blg70 Mar 02, 2014
    picture of a 10/3 wired to a Leviton 16693 15-Amp, 120-Volt, Grounded, Compact Automatic Reset Right Angle GFCI
  • 23 Answers
SOURCE:
jeltey
  • 44 Answers
SOURCE: need a wiring diagram for a barbie 12 volt two battery jeep !!!!!
When you mean wired in series you mean you tied the positive from one battery to the negative of the other. That will put 12 volts into the system. Is it supposed to run on 12 volts or 6 volts? If it is only supposed to be 6 volts you should wire the batteries in series. Negative to negative to negative wire to load. Positive to positive to positive wire to Load. Hope this helps
Posted on Dec 02, 2008
  • 152 Answers
SOURCE: 4 way switch
Posted on Feb 20, 2009
mydogisk
  • 50 Answers
SOURCE: Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Posted on Apr 13, 2009
SOURCE: Leviton Dimmer Switch wiring and
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Posted on May 20, 2010
SOURCE: how do I wire a double pole double throw 240 volt
You posted under GE timer, but added the brand name Intermatic.
GE and Intermatic timers are totally different.
Wiring below is for GE and will not apply to Intermatic.
Step 1) lets cover basic GE timer wiring for 240Volt load.
Be sure to set dip switches BEFORE applying power.
Step by step illustrations show on following link.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
Step 2) Load wires exit GE timer.
There are two Hot wires and 1 bare ground wire.
Step 3) Wire the outlets: You have 4 240Volt plugs.
This could mean a receptacle-type outlet like a clothes dryer outlet or air conditioner outlet.
Or it could be a twist-lock receptacle or extension-cord-type stage plug.
In all cases, look at screw color on device.
Connect Hot wires to brass colored screws.
Connect ground wire to green screw.
Step 4) Calculate total Load
Manual appears below: Look at Normally Open contacts. These contacts turn ON when timer turns ON.
http://waterheatertimer.org/15087-15207-56922-Manual-eng.pdf
Total load on all 4 plugs cannot exceed 2 HP
Generally, a 30 amp timer is rated for max 24 Amps or 6 amps per each of the 4 plugs.
Volts x amps = watts.
Take total watts and divide by 240Volts to get amps.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 20, 2011
Testimonial: "Fast response!! Very helpful, solved my problem. Thank you!!!"
How do i replace the power cord in an rv that has been cut off
3 wire cord or 4 wire cord?
3 wire would be normally 120 volts
4 wires would be 240 volts
don't know if that would be common in an RV? If 120, is it 15 amp or 20 amp?
Again, would not know if 20 A would be found in an RV? If 20 A you would have one position in the cord - Sideways.
Any with the presumption 120 Volt - Same for either 15A or 20 A , Black wire onto Gold lug.
White wire onto Silver lug.
Green wire onto Green lug
if 220, comment back
May 30, 2015 | Atwood GCH10A-4E GCH10A4E Gas and Electric...
I replaced my gfi outlets with leviton x789k plugs and now none of them work
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/How-to-add-outlet.html
http://waterheatertimer.org/Basic-house-wiring.html
leviton X789k? Or MX789?
Make sure your incoming Hot and Neutral connect to the wiring module that twist locks onto back of each device.
One strategy for discovering problem is replace the new leviton with ordinary outlet or put the old GFCI back into place and see if circuit is tripped..
Do this for each GFCI outlet and see if each issue is different or maybe the lot of Leviton products is defective.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 27, 2014 | Electrical Supplies
Wiring diagram, need help installing.
Single pole switch?
http://waterheatertimer.org/How-to-wire-switches.html
Add a comment and describe product and application.
Apr 10, 2013 | Leviton 5601 Decora Single Pole Switch, 15...
WHAT IS DIAGRAM FOR lEVITON PLUG RECEPTICLE
I am not sure what Leviton recepticle you have but i suppose you asking how to hook up a dryer cord? this below explains how to install both 3&4 wire dryer cords
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
3 WIRE CORD
The 3 wire cord goes just like this see the 2 wires on the outsides of the cord going to the black/red wires .The wire in the middle of the cord goes on the middle terminal on the cord block
Aug 24, 2011 | Whirlpool GEW9250 Electric Dryer
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
I have a black/white/ground wire coming from my power supply into my bathroom. I want to install a 274w combination device so as I can have one plug outlet and a switch for the shower fan.I need to see a...
1) In this situation we need to test the wires.
Electricians don't guess, they test, and a diagram would be guessing which wire color does what.
2) FYI: non-GFCI receptacle located in bathroom is not code, and device will have to be replaced when property is sold. The reason for GFCI is the likelihood of you holding defective electrical gizmo from China in one hand while putting other hand in running water. Or electrical gizmo falling into bathtub occupied by wife with large life insurance policy.
If you have kids using that bathroom, I want you to avoid using non-GFCI device.
3) Your new device has color-coded screws: Dark, brass, and silver.
These colors tell electrician how to wire the device.
4) Let's test to see which wire connects to which screw:
Separate wires.
Use ordinary 2-wire tester from hardware store.
Tape tester leads to wood sticks so hands are away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Hot wire connects to dark-colored screw on device.
Hot wire is identified.
Test Hot wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire. Neutral wire connects to silver screw, and will complete circuit to receptacle.
If box does not have a Neutral wire, the circuit to receptacle can be completed using ground wire on silver screw, but I am not recommending that.
Last wire goes to Load (light, fan, motor). Load wire connects to brass screw, and will complete circuit to Load.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on electrical device.
Leviton and Lutron both make GFCI switch-outlet combo.
Buy at Home Center or on-line
Leviton 7299
http://www.amazon.com/Leviton-7299-NI-15-Amp-125-Volt-Combination/dp/B000UJADW6
Jan 02, 2011 | Cooper Industries Cooper Wiring 274W...
I have an older Sundance Sentry Spa model 605. Over time, I have a problem with the 20A GFCI heating to the point where the insulation on the load wire connected to the GFCI becomes discolored. My Spa...
If you can find a higher rated GFCI receptacle it may help. But the first thing is to use 12 ga wire (NOT 14), and to get a good and tight connection to the load lug. Use the screw terminal, not the push-in holes. If you can remove the screw, do so. Then shape the end of the wire into a nice hook and then use a hammer and anvil to flatten it slightly. Then insert the screw nice and tight. If you can manage a 10ga wire, use that.
Aug 09, 2010 | Leviton 8599 GFCI Receptacle
Apr 12, 2009 | Leviton 8299 Combination Switch / Smart...
Electrical Supplies Logo
148 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
